neilca Posted September 24, 2017 Share Posted September 24, 2017 I replaced a bunch of parts in the front end and lifted it 2 inches. I have camber bolts in the top hole of the strut. Now how much chamber do I need. The only spec I have found says 0.17 positive degrees. I have never set up a car with positive camber. What is the factory spec for camber? Link to comment Share on other sites More sharing options...
hawairish Posted September 24, 2017 Share Posted September 24, 2017 0.17° is correct, with a min of -0.58° and max 0.92°. Difference between the L and R side should be less than 0.75°. Values are in the FSM, in SUspension chapter. Check the SDS section at the end of Front Suspension. Link to comment Share on other sites More sharing options...
neilca Posted September 24, 2017 Author Share Posted September 24, 2017 (edited) Thanks for the verification. I don't think I will need a second set of chamber bolts. Edited September 24, 2017 by neilca Link to comment Share on other sites More sharing options...
