Anyone still selling a subframe drop kit?
NovaPath
Realized that I have a blown passenger motor mount. The ONLY way I can see myself getting under this thing to fix it is if I can upgrade some stuff along the way ;).
Being that I have to drop the stinkin subframe down to replace this anyways, is anyone still making a subframe drop kit?
Thanks in advance!
  • 11 months later...
1) Raise chassis off ground and support with jack stands
2) Remove wheels
3) Remove struts
4) Remove front differential assembly
5) Lock steering wheel; remove steering U-joint from rack
6) Remove bracket securing P/S hose to subframe
7) Support subframe with a floor jack
8) Support engine with a floor jack (with a 2x4 or 4x4 placed between oil pan and jack)
9) Remove bolts securing subframe
10) Remove nuts on motor mounts
11) Lower the subframe about 5"
12) Insert spacer blocks between motor mounts and subframe
13) Insert spacer blocks between chassis and subframe
14) Install and tighten all of the hardware to secure the spacers to the chassis and to the subframe
15) Install "missing link" brace between left and right lower control arms
16) Attach strut spacers onto struts
17) Reinstall struts
18) Install new steering shaft/u-joints
19) Remove floor jacks
20) Reinstall front differential
21) Reinstall wheels
22) Now go lift the rear suspension. :)
Edited by XPLORx4
