Citron Posted July 7, 2017 Share Posted July 7, 2017 The cracked intake boot would be it, source of unmetered air, so basically a vacuum leak. Glad you found it. Link to comment Share on other sites More sharing options...
adamzan Posted July 7, 2017 Share Posted July 7, 2017 Yeah I think the wire colours are the same for both models. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RCWD21 Posted July 7, 2017 Author Share Posted July 7, 2017 The cracked intake boot would be it, source of unmetered air, so basically a vacuum leak. Glad you found it.I'm glad I found it too, that wasn't there a few days ago (the one on the top side) the bottom I'm not sure of since it was much smaller. Right now I have a lot of rtv sealing the cracks until i can get a new boot to replace it with. Sent from my SM-G920V using Tapatalk Link to comment Share on other sites More sharing options...
onespiritbrain Posted July 7, 2017 Share Posted July 7, 2017 I will be very interested to see if your p0420 code goes away. Sent from my iPhone using Tapatalk 1 Link to comment Share on other sites More sharing options...
RCWD21 Posted July 7, 2017 Author Share Posted July 7, 2017 The p0420 code only showed up after the o2 sensor code appeared so I'm hoping that since the pre-cat sensor is working and the post-cat sensor isn't the ecu thinks that the catalytic converter isn't working properly due to the out of spec reading Sent from my SM-G920V using Tapatalk Link to comment Share on other sites More sharing options...
RCWD21 Posted July 8, 2017 Author Share Posted July 8, 2017 Well I'll be trying out my intake boot fix today, so I'll post up what happens. Hopefully the surging issue will be gone Sent from my SM-G920V using Tapatalk Link to comment Share on other sites More sharing options...
RCWD21 Posted July 8, 2017 Author Share Posted July 8, 2017 Ok well the sealed boot did the trick with the surging, I just ordered a new boot to replace it with. All my parts should be here by the middle of this coming week so hopefully no more CEL! Sent from my SM-G920V using Tapatalk 2 Link to comment Share on other sites More sharing options...
RCWD21 Posted July 13, 2017 Author Share Posted July 13, 2017 I will be very interested to see if your p0420 code goes away. Well, I replaced the o2 sensor and cleared the codes. I've driven all of about 70 miles and all codes except the knock sensor code have not come back. I also replaced my torn intake boot. It feels like a whole new truck now. It runs and pulls so much better. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
