PathyNewbie Posted May 16, 2017 Share Posted May 16, 2017 Anybody have any experience with them? I got a '98 but I have 16" (255/70/16) mags and KO2's from a 2005 (I think?) Pathfinder. There is very little room between my strut and the tire, and it might just be rubbing (strange almost plastic crinkle noise when going over large speedbumps). Think I should get some spacers. I am getting the OME kit from North Shore - and I really do not want new steel wheels. Any recommendations on brand & amount of space? Thanks. 1 Link to comment Share on other sites More sharing options...
mjotrainbrain Posted May 16, 2017 Share Posted May 16, 2017 What size are the tires? It sounds like clearance on the strut isn't the problem, but more likely in the fender and wheel liner. If that is the case, I would highly suggest trimming over spacers. 2 Link to comment Share on other sites More sharing options...
PathyNewbie Posted May 16, 2017 Author Share Posted May 16, 2017 (edited) 255 / 70 / 16 BFG KO2's Edited May 16, 2017 by PathyNewbie 1 Link to comment Share on other sites More sharing options...
mjotrainbrain Posted May 16, 2017 Share Posted May 16, 2017 Those should fit perfectly fine. I'd check clearance with the inner fender and trim if necessary. 1 Link to comment Share on other sites More sharing options...
Gusthebus Posted May 16, 2017 Share Posted May 16, 2017 That tire should clear the strut. Might be close but it should be fine. Like previously stated you're probably encountering rub on the inner fender. If that is the case the spacers will most likely make the rub worse.you can easily move the mounting screws forward on your bumper cover to gain a lot of clearance. If still needed a heat gun works wonders. I would think that should be enough to solve your dilemma. If not you might need to send Fleury some $ and get some lift spacers. Link to comment Share on other sites More sharing options...
01Pathmaker Posted May 17, 2017 Share Posted May 17, 2017 2005 (R51) has a smaller bolt pattern than the R50 (96-04), therefore unless you're running adapters (which would double as wheel spacers), your wheels must be from either a R50 or gen 1 xterra/Frontier. With that said, if you're that close to the coil bucket on the strut, with that size tire, they very well might be from a xterra or Frontier, as the have a different backspace then the pathfinder. My 01 has about 3/8" clearance (close, but not uncomfortably) with stock SE wheels and 265/70/16's. Post up some pics of your wheel and clearance, that'll help point you in the right direction. Link to comment Share on other sites More sharing options...
