Moving To New Servers!
*Temporarily On Hold Due To Time Restrictions*
Members interested in helping test the new NPORA server platform, please contact RedPath88 via PM or email for further information.
Thank you,
Biggest tires without a lift?
  • Please log in to reply
13 replies to this topic
#1 OFFLINE   shawngs
shawngs
  • Members
  • Pip
  • 4 posts
  • Local time: 10:35 PM
  • Country:
  • Model:LE
  • Year:2002
Posted 19 April 2017 - 07:19 PM
Hi all, I know you are experts and I am but a lowly noob. I have a 2002 Nissan Pathfinder LE and need to replace the tires. What are the biggest size tires that I can put on it without significant rubbing and without having to have it lifted?
#2 OFFLINE   SellOut
SellOut
  • Members
  • Pip
  • 23 posts
  • Local time: 08:35 PM
  • Country:
  • Model:LE
  • Year:2002
Posted 19 April 2017 - 07:28 PM
31" just a guess but you may need some wheel spacers... I got all 4 spacers for $100 on eBay... 6x5.5 lug pattern and I got mine in 2"
Sent from my HTC6535LVW using Tapatalk
#3 OFFLINE   mjotrainbrain
mjotrainbrain
    What's an alignment?
  • TOTM Moderator
  • PipPipPipPipPip
  • 1,004 posts
  • Local time: 11:35 PM
  • Country:
  • Model:Other/Unknown
  • Year:2002
Posted 20 April 2017 - 02:29 AM
You should be able to fit 31's.  Might have slight rubbing depending on the condition of your suspension.  You should not need spacers for anything 31" or less, but you might depending on, again, the condition of your suspension and if the tires rub the inner fender lining.
#4 OFFLINE   fleurys
fleurys
  • Vendors
  • Others: Members
  • PipPipPipPipPip
  • 2,172 posts
  • Country:
  • Model:SE
  • Year:2001
Posted 20 April 2017 - 07:45 AM
Have a look here : http://www.nissanpat...m-or-oe-wheels/
you will find many users here with their personal experience with this.
Cheers,.
#5 OFFLINE   mickmutante
mickmutante
  • Members
  • PipPipPipPipPip
  • 594 posts
  • Country:
  • Model:LE
  • Year:2000
Posted 20 April 2017 - 01:24 PM
I run 265/70R16 AT tires... No spacers..
#6 OFFLINE   NovaPath
NovaPath
  • Members
  • PipPipPipPip
  • 301 posts
  • Country:
  • Model:LE
  • Year:2001
Posted 21 April 2017 - 01:46 PM
I ran 245/75/16 without a lift and had very saggy rear springs. Minimal rubbing.
#7 OFFLINE   shawngs
shawngs
  • Topic Starter
  • Members
  • Pip
  • 4 posts
  • Country:
  • Model:LE
  • Year:2002
Posted 24 April 2017 - 05:51 PM
Hey everyone, thank you so much for your input! I just realized I didn't mention the size of the tires that are on there now. They are the same as the ones that originally came with the vehicle when it was purchased new from the dealership in 2002. I don't know what all of the numbers mean but they are: R601 245/65R17 111H XL.
#8 OFFLINE   mjotrainbrain
mjotrainbrain
  • TOTM Moderator
  • PipPipPipPipPip
  • 1,004 posts
  • Country:
  • Year:2002
Posted 25 April 2017 - 02:23 AM
Those are the size that mine came stock with as well.  If you throw that number into a site like https://tiresize.com...ire-conversion/ you will find that your stock tire is 29.5x9.6R17, roughly 30x9.50R17.
#9 OFFLINE   LittleFR
LittleFR
  • Members
  • PipPipPipPip
  • 293 posts
  • Local time: 09:35 PM
  • Country:
  • Model:LE
  • Year:2001
Posted 28 April 2017 - 06:07 PM
Put your finger between the strut and the back of the tire. My tires on Sig leave me barely enough room to get my hand in with spacers.
If you go with spacers good luck finding hubcentric for a Pathy under $350
It's the same as Chevies and Yotas. ( I run Chevy lug centric spacers)
Edited by LittleFR, 28 April 2017 - 06:09 PM.
#10 OFFLINE   Megaton
Megaton
  • Members
  • PipPip
  • 89 posts
  • Country:
  • Model:LE
  • Year:1997
Posted 28 April 2017 - 09:14 PM
I put 31x10.50s on my stock sagging suspension but I mounted them on wheels with a 3.75 backspace. There was minimal rubbing on the plastic splash guards and I could live with that. There is no rubbing after the lift. There is a little tire poking out of the fender well but some Pacer fender flares covered that.
#11 OFFLINE   joserabagojr
joserabagojr
  • Members
  • Pip
  • 17 posts
  • Local time: 07:35 PM
  • Location:Saipan, Commonwealth of the Northern Mariana Islands
  • Country:
  • Model:SE
  • Year:1997
Posted 14 May 2017 - 04:05 AM
I think biggest tires with everything stock - Suspension, bumpers, and lift are:
265/70R15
265/70R16
265/70R17
Depending how big your rims are. Considering everything is stock, it might be a stock 15x7 Alloy rim.
You can get bigger, but you need lift spacers and others.
Cheers
#12 OFFLINE   micahfelker
micahfelker
  • Members
  • PipPipPipPip
  • 284 posts
  • Country:
  • Year:1996
Posted 15 May 2017 - 08:22 PM
Not sure why everyone thinks 31's are the biggest that will clear stock. I fit 32's (265/75r16) with no lift and no rubbing, and I did the same amount of trimming that's common for 31's. I had pretty blown struts too. I can send pictures of how they fit if you want.
#13 OFFLINE   01Pathmaker
01Pathmaker
  • Members
  • PipPipPipPipPip
  • 595 posts
  • Country:
  • Model:SE
  • Year:2001.5
Posted 16 May 2017 - 06:55 PM
96-99 (pre-facelift) are typically able to fit larger tires easier than 99.5-04 (facelift) due to different flares and bumpers. Cleared 31's with a little room to spare on my 96, had to do medium-duty springs (~3/4" lift) to clear 265/70/16 (metric 31's) on my 01.
#14 OFFLINE   micahfelker
micahfelker
  • Members
  • PipPipPipPip
  • 284 posts
  • Country:
  • Year:1996
Posted 16 May 2017 - 08:51 PM
Ah okay that makes a lot of sense. I did still have my fender flares on but I had to take off the front mud flaps
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
