haakon Posted April 12, 2017 Share Posted April 12, 2017 Hi all; newbie here with what might be (I'm hoping!) a stupid simple question. The car's got a bit of a wobble and sway on the highway- feels kinda like it's got a heavy load in the back but it doesn't. The folks at Les Schwab did an alignment (didn't hardly change anything, and it doesn't feel any different, so I'm thinking that that wasn't the problem). They said it needs new rear sway bar bushings. Now the bushings look and feel fine to me, both the ones in the middle around the sway bar/stabilizer and the doughnut shaped ones on the attachment rods. I mean, they're present, don't look chewed up and I can't feel any cracks or anything. Seems to me like this means they're fine, but I don't know a lot. I watched MrJim's video on replacing the front sway bar bushings and they were obviously shot. So, question is: can sway bar bushings go bad without any apparent sign? Thanks for any advice! Haakon 1 Link to comment Share on other sites More sharing options...
RCWD21 Posted April 12, 2017 Share Posted April 12, 2017 Have you checked the rear trailing arm bushings and the panhard rod bushings? Is your tire pressure correct all the way around? As long as everything is firm with the sway bar I don't think that is your issue. Sent from my SCH-I545 using Tapatalk Link to comment Share on other sites More sharing options...
Mrelcocko Posted April 14, 2017 Share Posted April 14, 2017 Replace lower and upper trailing rod bushings. Easier to replace entire trailing arms instead of just the bushings. I have a 97 QX4 that was doing the same thing. I replaced the upper and lower trailing arms plus the sway bar links and the sway bar bushings all on the rear end. You have to press the bushings in if installing only bushings. I didn't do anything with the Pan Rod not saying it wouldn't help your situation. I found all I needed on ebay for around 200$ I also installed new shocks. Sent from my SM-G530T using Tapatalk Link to comment Share on other sites More sharing options...
maddmark1981 Posted April 17, 2017 Share Posted April 17, 2017 I got the same problem. I believe it made a difference when I changed out the tension rod bushings. They were shot Sent from my LG-H812 using Tapatalk Link to comment Share on other sites More sharing options...
Mrelcocko Posted May 13, 2017 Share Posted May 13, 2017 Hi all; newbie here with what might be (I'm hoping!) a stupid simple question. The car's got a bit of a wobble and sway on the highway- feels kinda like it's got a heavy load in the back but it doesn't. The folks at Les Schwab did an alignment (didn't hardly change anything, and it doesn't feel any different, so I'm thinking that that wasn't the problem). They said it needs new rear sway bar bushings. Now the bushings look and feel fine to me, both the ones in the middle around the sway bar/stabilizer and the doughnut shaped ones on the attachment rods. I mean, they're present, don't look chewed up and I can't feel any cracks or anything. Seems to me like this means they're fine, but I don't know a lot. I watched MrJim's video on replacing the front sway bar bushings and they were obviously shot. So, question is: can sway bar bushings go bad without any apparent sign? Thanks for any advice! Haakon So did you get it fixed? Sent from my SM-G530T using Tapatalk Link to comment Share on other sites More sharing options...
