Cuong Nguyen Posted February 21, 2017 Share Posted February 21, 2017 Does anyone know how the antenna is secured down on the fender? I have the whip and not the motorized one. Mines just sitting in the hole. Link to comment Share on other sites More sharing options...
RCWD21 Posted February 23, 2017 Share Posted February 23, 2017 If you remove the inner fender liner you'll be able to see a bracket sticking off of the main body that the base of the antenna slides through, there may or may not be an aluminum ground strap (looks like a twisted up strip of aluminum with eyelets on both ends). Other than that there's just a single screw that holds the plastic top down to the fender. If you're not able to seat the antenna base flush with the fender you're not through the hole in the bracket mentioned above. Hope this helps! Been awhile since I've been on here due to work Sent from my SCH-I545 using Tapatalk Link to comment Share on other sites More sharing options...
