wd21fan Posted February 2, 2017 Share Posted February 2, 2017 Hi all, I have had a 1995 Pathfinder XE for some time and have been eyeing black primed front bumper and related parts. I found the following for 1995 Nissan Pickup XE on ebay: http://www.ebay.com/itm/FRONT-BUMPER-BLACK-VALANCE-FINISHER-VALANCE-BRACKET-10PC/121274412433?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D20131003132420%26meid%3D4f176db984604bb9ab895da43d0f6de5%26pid%3D100005%26rk%3D6%26rkt%3D6%26sd%3D171747440030 It has front center bumper, ends, park/signal lamps, brackets and front valance. The price is $147+$62 shipping. Any advice if these pickup parts would fit on 1995 wd21; also if you know of similar deals for 1995 wd21 that would be awesome too. Thanks, Link to comment Share on other sites More sharing options...
wd21fan Posted February 2, 2017 Author Share Posted February 2, 2017 I found following for $114 + $44 shipping - does the price seem okay? http://www.ebay.com/itm/FRONT-BUMPER-BAR-END-FINISHER-PARK-LIGHT-BLACK-7-/201035793117?fits=Year%3A1995%7CMake%3ANissan%7CModel%3APathfinder%7CSubmodel%3AXE%7CEngine+-+Liter_Display%3A3.0L&hash=item2eceaac2dd:g:iOEAAOSw54xUWbTi&vxp=mtr Link to comment Share on other sites More sharing options...
Slartibartfast Posted February 2, 2017 Share Posted February 2, 2017 I think the pickup body sat a little higher than the Pathy body, so the brackets may be different if you go for a HB bumper. I would be kinda surprised if Nissan changed the bumper itself. What I'd do is look up the bumper for the Hardbody and the Pathfinder on Rockauto, or factorynissanparts.com, and see if the part number is the same. Same PN, same part. The one you posted doesn't look bad but I do notice the turn signals are a little different from stock. 1 Link to comment Share on other sites More sharing options...
wd21fan Posted February 2, 2017 Author Share Posted February 2, 2017 I think the pickup body sat a little higher than the Pathy body, so the brackets may be different if you go for a HB bumper. I would be kinda surprised if Nissan changed the bumper itself. What I'd do is look up the bumper for the Hardbody and the Pathfinder on Rockauto, or factorynissanparts.com, and see if the part number is the same. Same PN, same part. The one you posted doesn't look bad but I do notice the turn signals are a little different from stock. Thanks; I checked factorynissanparts.com - front bumper center has different part numbers for the hardbody and pathfinder. Guess so far the second ebay link is the better option. If only I could find a used ARB wd21 bumper, that would be great. Link to comment Share on other sites More sharing options...
Slartibartfast Posted February 2, 2017 Share Posted February 2, 2017 Thanks; I checked factorynissanparts.com - front bumper center has different part numbers for the hardbody and pathfinder. Guess so far the second ebay link is the better option. If only I could find a used ARB wd21 bumper, that would be great. Interesting that they'd go to the trouble of designing two different bumpers. Good to know! Link to comment Share on other sites More sharing options...
KovemaN Posted February 2, 2017 Share Posted February 2, 2017 As far as I know, the 2wd D21 pickups sat at the same height as the WD21 Pathfinders. The 4wd D21 had risers on the body mounts that made it sit about 1.5" higher off of the frame. Link to comment Share on other sites More sharing options...
Mattybilt Posted February 28, 2017 Share Posted February 28, 2017 The bumper is the same, the brackets are different. But you can use pathy brackets and it will fit. I have a chrome truck bumper on my 95 i got from the junk yard. The front valance is different too. The trucks use bolt/screws into the core support and pathys use clips. The truck valance does line up with most of the holes and fender flares but you would have to figure out how to mount it solidly. Link to comment Share on other sites More sharing options...
