Moving To New Servers!
*Temporarily On Hold Due To Time Restrictions*
Members interested in helping test the new NPORA server platform, please contact RedPath88 via PM or email for further information.
Thank you,
97 QX4 Fixer Upper
  • Please log in to reply
118 replies to this topic
#101 OFFLINE   micahfelker
micahfelker
  • Members
  • PipPipPipPip
  • 284 posts
  • Local time: 07:07 PM
  • Country:
  • Year:1996
Posted 27 June 2017 - 10:51 PM
Great news guys, no more P0300! After replacing everything known to man on this problem, here is my conclusion and the solution. Whatever you do don't ever buy an aftermarket distributor for the 3.3L it will not work I promise you. I ended up getting one from Advanced for $230 which was a waste of money and since I've used it I cannot take it back. So what I did was used the parts inside and rebuilt my original distributor which in reality was good the problem was my fuel injectors. She purrs like a kitten now. I'm almost done. I found this wheel and tire at my local pull a part. Now all I need is 3 more. I also took the headlights out of a 2000 model and they fit perfectly. All I had to do was a little bit of wiring. 320216788732ee4042218b2fda3c5c80.jpg8622d088840c4dabd40266c54c4bd640.jpga3aa18f01ea2f9a477ee078788193a01.jpgf56d9ea2142500c1cb82cf639f27e81e.jpg
Sent from my SM-G530T using Tapatalk
I'm curious wether or not those marker lights would fit with my headlights. They look really awesome.
#102 OFFLINE   Mrelcocko
Mrelcocko
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 528 posts
  • Local time: 09:07 PM
  • Country:
  • Model:XE
  • Year:1998
Posted 28 June 2017 - 05:37 AM
I'm pretty sure they would.
#103 OFFLINE   Mrelcocko
Mrelcocko
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 528 posts
  • Country:
  • Model:XE
  • Year:1998
Posted 28 June 2017 - 05:39 AM
They should fit perfectly.
#104 OFFLINE   micahfelker
micahfelker
  • Members
  • PipPipPipPip
  • 284 posts
  • Country:
  • Year:1996
Posted 29 June 2017 - 01:10 AM
Let me know if you find another set.
#105 ONLINE   mjotrainbrain
mjotrainbrain
    What's an alignment?
  • TOTM Moderator
  • PipPipPipPipPip
  • 1,004 posts
  • Local time: 10:07 PM
  • Country:
  • Model:Other/Unknown
  • Year:2002
Posted 29 June 2017 - 08:31 AM
I have two sets of the ones from a 2002 if you're interested.  They look a little different but are the same shape I think.
#106 OFFLINE   micahfelker
micahfelker
  • Members
  • PipPipPipPip
  • 284 posts
  • Country:
  • Year:1996
Posted 29 June 2017 - 08:46 AM
I don't think it's the same. I already know the facelift marker lights won't fit, I'm just looking for the specific ones that have a little black in them like this.
#107 ONLINE   mjotrainbrain
mjotrainbrain
  • TOTM Moderator
  • PipPipPipPipPip
  • 1,004 posts
  • Country:
  • Year:2002
Posted 29 June 2017 - 08:47 AM
Oops, I thought you said fog lights for some reason.  Don't have those.  I don't think they'll fit unfortunately, as the shape of the QX4 fender is different to compensate for the different shape of the marker lights.  (They slope back.)
#108 OFFLINE   Mrelcocko
Mrelcocko
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 528 posts
  • Country:
  • Model:XE
  • Year:1998
Posted 29 June 2017 - 04:17 PM
I'm pretty sure the marker lights will work up until 2000 models anything after that no they won't. I'm not a 100% sure
#109 OFFLINE   Mrelcocko
Mrelcocko
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 528 posts
  • Country:
  • Model:XE
  • Year:1998
Posted 01 July 2017 - 08:53 AM
The lights come apart and maybe you can paint the inside black. Just the black strip your talking about.
#110 OFFLINE   Mrelcocko
Mrelcocko
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 528 posts
  • Country:
  • Model:XE
  • Year:1998
Posted 01 July 2017 - 09:06 AM
The check engine light came on, ran the codes. Got a p1441 Vacuum cut valve. Before the check engine light I noticed I would smell gas after stopping the vehicle and getting out it was a very faint smell of gas. Looked online and a vacuum cut valve was about 50 bucks that was the cheap one. Called the local auto parts stores their prices for a vacuum cut valve 90 bucks. That's ridiculous in my book. It's a little piece of plastic that has 4 hoses connected to it. Went to my local Pull A Part got one for five bucks. I bought 2. I got one off an Xterra and another one off of an 02 QX4 just in case I broke one installing it. No more check engine light and no more gas smell. Another job completed:)
#111 OFFLINE   Mrelcocko
Mrelcocko
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 528 posts
  • Country:
  • Model:XE
  • Year:1998
Posted 03 July 2017 - 04:42 PM
Hey guys back again. After installing a factory distributor it got rid of my p0300 code. Great right? Well maybe somewhat. Now during acceleration I feel the engine surging. On flat ground not so noticeable, but under a load or uphill and it's like driving miss daisy. While accelerating I can clearly see the tach needle surge. At idle i feel and hear a slight miss but no CIL. During acceleration I don't feel a miss just lacking power and takes forever to get up to speed. Please help!!!
#112 OFFLINE   Bunchie
Bunchie
  • Members
  • PipPipPipPip
  • 226 posts
  • Country:
  • Model:LE
  • Year:2002
Posted 04 July 2017 - 11:11 PM
THAT sounds like no distributor vacuum advance. I may be talking out of my butt (correct me if I'm wrong) but the distributor needs to be mechanically advanced when you put ur foot into it, ie: vacuum to suck the diaphragm and move the dist base plate, in turn advancing the spark timing. If you have no vacuum advance, any acceleration relies on the weights on the base plate to do any advancing and THAT'S painfully slow.
Does it behave that way in P or N? W/the 3.3, ur still dealing a w/vacuum controlled engine. 3.5(w/I got)is ALL electronic. Different beast entirely.
Get/borrow a simple vacuum guage-most are even marked "Vacuum Leak"(mine is) & see what it says. The other test is: remove cap/rotor, plug a long enough piece of vac hose to the vacuum diaphragm, while looking at the dist base plate, suck on the hose and see if the base plate turns slightly. If it don't, either the diaphragm/rod/plate are the problem (maybe check ur old one 1st.
Lemme know what you find.
Cheers, V
#113 OFFLINE   Mrelcocko
Mrelcocko
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 528 posts
  • Country:
  • Model:XE
  • Year:1998
Posted 05 July 2017 - 08:42 AM
No vacuum advance. All controlled by computer. Thanks anyway though my friend. Come to find out had a vacuum leak. A bad hose.
#114 OFFLINE   Mrelcocko
Mrelcocko
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 528 posts
  • Country:
  • Model:XE
  • Year:1998
Posted 14 July 2017 - 02:59 PM
Hey guys back again. I got this QX4 back in January and have a lot of sweat invested in it. Finally got rid of the P0300 after chasing the issue it came to be the distributor. Well now here is my problem. This thing runs absolutely perfect other than the fact the SES/CEL comes on for a few driving cycles then goes off and comes back on again. So it comes off and on. Ran the codes and getting the P0300 again. Right now the CEL IS OFF! Does anybody know why this is occurring? Like I said the car runs great it's just the check engine light will come on and go off on its own.
#115 OFFLINE   Mrelcocko
Mrelcocko
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 528 posts
  • Country:
  • Model:XE
  • Year:1998
Posted 03 August 2017 - 04:18 PM
Hey guys back again and still continuing to add stuff here and there. I didn't like the way the driver side window switch lit up, way too dim at night time. Making it really hard to see. Every time I'd roll the window down at night I would always hit the back passenger door switch on the drivers side. So to match every other switch I have in the vehicle I decided to install a red LED to brighten things up. Now I won't have a problem finding the switch. I also installed yellow fog lights but ended up taking them back out and installing some bigger ones. They really go good with the car in my opinion. I used a genuine Nissan relay for the wiring on the fog lights and made my own bracket so I could make it look as close to factory as possible. I also put a set of factory 17inch wheels on it. I guess I can say it's complete, but of course I'm never satisfied so I'm sure there will be more to come.
Here's a list of the updates. Steering wheel from an i30, headlights from a 2000 Quey,taillights from a 03 Pathy, wheels from an 01 Quey, fixed antenna,replaced rear pass side quarter glass,distributor,plugs,wires,thermostat,ball joints,upper and lower control arms,shocks,stabilizer bushings front and back, stabilizer links front and back, fixed rusted out step rails with some from a 99 quey,installed factory hitch,LED lighting behind guages,shifter and in all switches,refurbished roof rails, marker lights,fog lights and blinker lights,3 layers of undercoating front to back,new exhaust from cats to back,exhaust heat shield pass side, o2 sensor upstream pass side,replaced vacuum cut bypass valve,purchased new key fobs and new throttle body boot. I don't think I left out anything. For a 20 year old vehicle it still turns heads and thats exactly what I wanted to do when I bought it. I acquired this 97 Quey on January 4th 2017. It's taken me eight months exactly to do what I wanted to do. I love my Nissans! Rock on Peeps!
6f0de505fc726d21399ab3d2229cd693.jpg41b95b2ca718ac920d5d8bbcaea8fe66.jpg763e68e36e4065a5298bcdae053101f5.jpg5ad4b712bca4ba3fce216d9c22fae690.jpg8cedaf3ccb711db6cefe89028cc84959.jpg5c997fff7bcae1ba440d1c22dffee0da.jpgba7e37f96b17d5c46c116bc9b67aa195.jpg9510f7a0425a7cff516ba5f270a7f65d.jpg811ccab39987ca35bccea9c1c12133bf.jpg
#116 OFFLINE   Mrelcocko
Mrelcocko
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 528 posts
  • Country:
  • Model:XE
  • Year:1998
Posted 14 August 2017 - 07:22 PM
FINALLY COMPLETE! I respect the guys that go off-road. Kudos! I don't do that. I'm more of a cosmetic kinda guy. Here's my 97 Quey. It's been 8 months since I got her and with it came a lot happy times and pist off times, but we made it through. Hope you guys like my ride and the upgrades I did. I love the R50's Jr50'sd2c51418c7117f796b7e2816b118207f.jpgaa8eb7732101f5fec08f86d8fb2ba525.jpg36be217023c465248dd6d85956a5bb2c.jpgeec9de73b238868b04075ba0a422bbec.jpgc95802bc6fecb44b90d5fb1d18e20672.jpg31e0d68a3d4c7a8bebc1207e403ae2f6.jpg5562befbbbcc44fc9daa4a6efcabcbee.jpgdd4780e6099f50c76fa8414c17ae2499.jpg399534353a2dedc7c9d8d7e1e4e94074.jpg
Sent from my Z836BL using Tapatalk
#117 OFFLINE   Mrelcocko
Mrelcocko
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 528 posts
  • Country:
  • Model:XE
  • Year:1998
Posted 16 May 2018 - 02:29 PM
New front end on my 97 Quey.d553266b51be2b3443b5cc38106fc659.jpgf9fa99d3b14b774670655506a8ea3d90.jpg25fc18764d9ed319715feb95d97799c9.jpg79255531106d1c8df87b65e66121bdaf.jpg4a6728035bcf2d9e28393c10484570fa.jpgc20e8c7a0adb48bf1429ef297fa8e271.jpgb12aaf58672e4e04ed1d0225659f3778.jpgb722ce21104dba0549d407c679f1e1e0.jpgd5dcabce895121f317b96cb61f8cc754.jpg
Mr Cox R50
#118 OFFLINE   Bax03SE
Bax03SE
  • Members
  • PipPipPip
  • 151 posts
  • Local time: 03:07 AM
  • Country:
  • Model:SE
  • Year:2003
Posted 19 May 2018 - 05:30 PM
Looking good!
#119 OFFLINE   onespiritbrain
onespiritbrain
  • Members
  • PipPipPipPipPip
  • 417 posts
  • Country:
  • Model:LE
  • Year:1999
Posted 19 May 2018 - 07:10 PM
Mine is many multiple millions of times dirtier than that.. it’s basically just a big ball of dirt rolling down the road.
Edited by onespiritbrain, 19 May 2018 - 07:11 PM.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
