Noise on acceleration - bearing? Water pump?
  • Please log in to reply
6 replies to this topic
#1 OFFLINE   swedecore
swedecore
  • Members
  • Pip
  • 8 posts
  • Local time: 04:54 PM
  • Country:
  • Model:XE
  • Year:1995
Posted 08 January 2017 - 11:13 PM
Over the past 1000 miles I have been hearing a whirring/whizzig sound from 1-3k RPM upon acceleration. Video is here ->
I bought my pathy used of a dealer at 130k miles (now at 141k) , had no history so i had him agree to change the crankshaft seals and the timing belt free of charge. I didnt know the water pump should be done then too. Anyways, I have no idea if the previous owner did the timing belt/water pump job.
#2 OFFLINE   RCWD21
RCWD21
  • Members
  • PipPipPipPipPip
  • 740 posts
  • Local time: 07:54 PM
  • Country:
  • Model:SE
  • Year:1987
Posted 08 January 2017 - 11:33 PM
Do you have an auto or a manual transmission? If it's a manual it could be an input shaft bearing that has gone bad or even something wrong with the clutch.
Have you tried popping the hood and revving it while you're standing there to see if anything stands out? It could be on my end but that almost sounds like a metal on metal whirring noise like a bad bearing would make.
One easy spot to check is your AC idler pulley bearing, if you can wiggle it at all then it's starting to go bad. I've seen them go bad to the point where the pulley itself started rubbing on the bracket behind it and making a similar noise. Another possibility is a failed power steering pump bearing, they make a horrible racket when they go bad.
Does it make any resemblance to the noise just idling or is it only when revving it up?
Sent from inside my potato
Edited by RCWD21, 08 January 2017 - 11:34 PM.
#3 OFFLINE   Slartibartfast
Slartibartfast
  • Members
  • PipPipPipPipPip
  • 4,743 posts
  • Local time: 05:54 PM
  • Country:
  • Model:SE
  • Year:1993
Posted 09 January 2017 - 03:53 AM
Hmm. Yeah, aircon idler is an easy check, but power steering sounds likely too. If you hold it where it's making noise, let's say 2k, and work the steering, does the noise change?
The nice thing about a V-belt system is that you can remove the drive belts one by one to see which accessory is making the noise (and hopefully it is just an accessory).
#4 OFFLINE   swedecore
swedecore
  • Topic Starter
  • Members
  • Pip
  • 8 posts
  • Country:
  • Model:XE
  • Year:1995
Posted 09 January 2017 - 07:50 AM
I have a manual, the noise persists when revving with the clutch in. The noise exists when idling as well but it is quieter.
I changed all my V belts about 5k miles ago and could have overtightened the ac belt and/or that pulley.
I will take off the belts 1 at a time to try and identify the issue.
#5 OFFLINE   snowboard419
snowboard419
  • Members
  • PipPipPip
  • 179 posts
  • Local time: 06:54 PM
  • Country:
  • Model:SE
  • Year:1991
Posted 10 January 2017 - 07:33 PM
Either remove belts or get your hands on a mechanics stethoscope they run less than 20 bucks and you can pinpoint noises like that in no time just place the probe on the pulley bolt or the accessory and see which one is making noise, pull the belt to confirm and your set. Can save alot of time.
#6 OFFLINE   Citron
Citron
  • Members
  • PipPipPipPipPip
  • 962 posts
  • Country:
  • Model:SE
  • Year:1992
Posted 10 January 2017 - 07:51 PM
Agreed. Mechanics stethoscope is the way to go.
#7 OFFLINE   adamzan
adamzan
    Hi
  • Members
  • PipPipPipPipPip
  • 17,780 posts
  • Local time: 08:54 PM
  • Country:
  • Model:SE
  • Year:1994
Posted 11 January 2017 - 06:44 AM
Almost sounds like a failing alternator or power steering pump.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
