UPDATE - The host suffered a "Catastrophic Hardware Failure" (*specifics not shared) on 01/13 and the "latest available" backup for the website and database were restored.  At this point they have been unable to recover any later versions of the database.
     We are going to give them another 72hrs to pull off a miracle and find something later than 05/21 before we fully move forward with normal forum operations.  Maybe we'll luck out, but to be perfectly honest, it's not looking good.
     It is still recommended that new members wait to register for the time being, as any new accounts created before our final decision on a path forward is made, may not exist once this is taken care of. This is also true for new topics, posts, status updates, profile & account changes, etc.
As always, we appreciate your patience as ask that you hold on just a little longer.
-NPORA Mod Team
*Updated: 01/17/2022 6:54PM PST
Fog Light Upgrade
Dragster
I have a Pathfinder SE that I wanted replace the fog lights with a pair of LED units. problem is they won't work when wired to the current setup? put the old ones back and they work. as many folks know the fogs are wired with the headlight low beams thru the relay. could this be limiting the current to the LEDs. I may just run a seperate line from the factory fog light switch, all suggestions welcomed.
If the halogens work, you have power and ground to the socket. No need to screw with the circuit. LEDs shouldn't draw more power than the halogens that were there. Like K9SAR said, you've probably got the bulbs in backwards.
If you want to test the LEDs, take a couple of jumper leads (or wire scraps, whatever) and test the bulb straight from the battery. If it doesn't light, reverse polarity. If it still doesn't light, there's something wrong with the bulb. If the bulb does light, try it in the fog socket again, see if it works, turn it around if it doesn't.
Any bulb needs + and -, no matter the type. You do notice flickering more with LEDs than with incandescents. This is because an incandescent light has a hot filament inside that takes a second to cool down and quit glowing after power is cut. Interrupt the power for a fraction of a second and you probably won't notice. Cut the power on an LED and it goes dark instantly.
