Mastindanes Posted June 1, 2016 Share Posted June 1, 2016 (edited) My pathfinder wasn't slipping what so ever. I was driving it down the road with no noise, no slipping, it just quit pulling. It doesn't even try to move no matter what gear it's in. It has 238,147 miles on it and I've never had any problems out of it. Is the transmission shot you think? I'm having a hard time locating a used 2x2 automatic transmission around Harrison,Tennessee. Edited June 1, 2016 by Mastindanes Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted June 1, 2016 Share Posted June 1, 2016 I know a guy with a transmission from an xterra 2wd and in Tennessee. How's the fluid color and level? When was the last time the fluid was changed? Original copper radiator or plastic? Could be electrical like one of the solenoids. Sent from my SAMSUNG-SM-N920A using Tapatalk Link to comment Share on other sites More sharing options...
Mastindanes Posted June 1, 2016 Author Share Posted June 1, 2016 Will an terra bolt up to the engine without a problem? I changed the transmission filter and fluid around a year ago. The fluid looks fine.I think the radiator is the original. I am not the first owner. I've had it for 7-8 years. The only thing I've replaced was alternator, starter, brakes, plugs, plug wires, transmission filter, fluid, and oil. It runs great! Link to comment Share on other sites More sharing options...
adamzan Posted June 2, 2016 Share Posted June 2, 2016 Sounds like the torque converter to me. But it could be anything. 1 Link to comment Share on other sites More sharing options...
Slartibartfast Posted June 2, 2016 Share Posted June 2, 2016 TC sounds likely to me too. If it was just a solenoid or something I would still expect some response in some gear. The 4x X transmissions are supposed to bolt in with little fuss. I assume the 2x X trans would do the same. Link to comment Share on other sites More sharing options...
Terranovation Posted June 2, 2016 Share Posted June 2, 2016 This might sound stupid but did you check the wiring harness next to the trans pan? Maybe it came loose? Link to comment Share on other sites More sharing options...
silverton Posted June 2, 2016 Share Posted June 2, 2016 When you start it does the transmission show any codes? The light on the Eco/Power switch will stay solid for a few seconds upon starting it if not. If it starts to blink, count! A 4x4 transmission will work, you just don't need the transfer case. You'd have to separate it and swap the tail housing from your original transmission to it. And yes, an Xterra transmission is plug and play in our WD21 Pathfinders. Link to comment Share on other sites More sharing options...
