Another Code 51 Injector question...
Trogdor636
Working on a friends Pathfinder, had a rat gnaw on injector 4 wire. Cleaned up wire, put a new connector in, but the vehicle is still throwing the code 51. Injector OHMS out the same as the others. I can hear it clicking with my mechanic stethoscope. Harness has power with a test light, and the wires have continuity. My question is, when the vehicle is running, the OHMS change for the other 5 injectors, however this injector stays at 13-14. Could it still be a faulty injector? Bad wiring? Needs to be smogged soon! Any ideas?
I'm not great at electrical a tuff but have you tried disconnecting the battery to reset the code? Not sure what a stuck injector would give you when tested either
Sent from my SAMSUNG-SM-N920A using Tapatalk
I have reset the code at the ECM multiple times, not by unplugging the battery. Code will be cleared, you start it and no CEL, turn it off, and then the CEL pops back on. Injector being stuck open is what I am starting to believe.
