Dma251 Posted April 12, 2016 Share Posted April 12, 2016 I am welding on a set of TG rock sliders on my WD21, and had to grind the factory paint off the weld areas and will need to paint those areas as well as the rails. In the past I have used POR15, ospho and redox bases, and just plain satin black spraypaint, with varying degrees of success. My frame is rust free, and I'd like to keep it that way, so what do you all use? Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted April 12, 2016 Share Posted April 12, 2016 I've had good luck with just using a few coats Rustoleum paint. Link to comment Share on other sites More sharing options...
PathyAndTheJets Posted April 12, 2016 Share Posted April 12, 2016 I'd use por-15 then paint over it with whatever paint you'd like. I've had good luck with vht rollbar and chassis paint. Link to comment Share on other sites More sharing options...
DarekG Posted April 12, 2016 Share Posted April 12, 2016 Por-15 then paint over it with whatever. Link to comment Share on other sites More sharing options...
kdj Posted April 13, 2016 Share Posted April 13, 2016 On my last Pathfinder I tried Rustoleum. It lasted about 6 months. Por-15 doesn't seem to be available in my area but lately I've heard it is good(last two posts)...I'd love to try it. Anybody think bedliner would work better? Link to comment Share on other sites More sharing options...
adamzan Posted April 13, 2016 Share Posted April 13, 2016 They have it at canadian tire. In the section with all the body work stuff. Link to comment Share on other sites More sharing options...
kdj Posted April 13, 2016 Share Posted April 13, 2016 Thanks, didn't see it when I was last in Brockville. Link to comment Share on other sites More sharing options...
Dma251 Posted April 13, 2016 Author Share Posted April 13, 2016 After I tack-welded the rails into place, I cut the welds holding the mounts to the frame and finished the welding on a bench. After that I wiped them all down with paint thinner to remove the mill-oil followed by rubbing alcohol, and put two coats of POR15 on them. I will do another coat tomorrow morning, and then let them cure for a few days. Then weld them onto the frame and POR over the welds. Probably top-coat on the truck with semi-gloss black. The POR15 is SHINY but not UV stable. Will post a final pic when they're done! 1 Link to comment Share on other sites More sharing options...
maddmark1981 Posted April 14, 2016 Share Posted April 14, 2016 Nice job, your lucky to be rust free, I'd love to find a rust free 95 Sent from my LG-D852 using Tapatalk Link to comment Share on other sites More sharing options...
karlmagnum Posted April 26, 2016 Share Posted April 26, 2016 If the frame is rust-free, por15 is not the best product to use since it is meant to be painted on rusted surface. I would suggest a good epoxy primer. Link to comment Share on other sites More sharing options...
