cntryboy_88 Posted June 28, 2016 Author Share Posted June 28, 2016 Well got everything back together after replacing a valve cover and she is running and driving again! Gonna take some getting used to driving a lifted pathfinder...I currently have no sway bars on it gonna see how it does and I may re add the front Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
Enjoi408 Posted June 30, 2016 Share Posted June 30, 2016 Is removing the front sway bars really THAT big of a difference driving one road??? I was considering taking off mine. Link to comment Share on other sites More sharing options...
cntryboy_88 Posted June 30, 2016 Author Share Posted June 30, 2016 Is removing the front sway bars really THAT big of a difference driving one road??? I was considering taking off mine.It definitely takes some getting used to...tomorrow will be the true test I'm driving on the highway Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
Enjoi408 Posted June 30, 2016 Share Posted June 30, 2016 Keep me posted! Link to comment Share on other sites More sharing options...
cntryboy_88 Posted June 30, 2016 Author Share Posted June 30, 2016 Keep me posted! Had it up to 65...did just fine...just gotta take it slow around the corners Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
Enjoi408 Posted June 30, 2016 Share Posted June 30, 2016 How much swaying was there during turns? Link to comment Share on other sites More sharing options...
cntryboy_88 Posted June 30, 2016 Author Share Posted June 30, 2016 Quite a bit...not unmanageable but you can definitely feel it Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
cntryboy_88 Posted June 30, 2016 Author Share Posted June 30, 2016 Fixed my crooked antenna Then had a little fun Sent from my SM-N920V using Tapatalk 2 Link to comment Share on other sites More sharing options...
Enjoi408 Posted July 3, 2016 Share Posted July 3, 2016 Looking beastly! Got a lot of rake there I see. Which springs did you use in the rear? Link to comment Share on other sites More sharing options...
cntryboy_88 Posted July 3, 2016 Author Share Posted July 3, 2016 Looking beastly! Got a lot of rake there I see. Which springs did you use in the rear?Yea its weird sometimes there looks like a lot and sometimes it looks like none...I used the 6.5" wj lift coils Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
Enjoi408 Posted July 3, 2016 Share Posted July 3, 2016 Did you cut the pig tail off the top on the 6.5 WJ coils? Link to comment Share on other sites More sharing options...
cntryboy_88 Posted July 3, 2016 Author Share Posted July 3, 2016 Yep sure did Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
CDN_S4 Posted July 5, 2016 Share Posted July 5, 2016 Did you end up putting the front sway bar back in? With the IFS there really is no benefit in removing it. If anything, it should help prevent damage to components that are very sensitive to abuse. The front doesn't do well with flex. Plus I think it will be unsafe on the road, especially on a lifted Pathy. If you ever had to swerve hard to avoid an accident, it's hard to predict that it will handle how it should and who knows what could happen. The rear however can go. I've removed mine permanently and never looked back. Link to comment Share on other sites More sharing options...
cntryboy_88 Posted July 5, 2016 Author Share Posted July 5, 2016 Did you end up putting the front sway bar back in? With the IFS there really is no benefit in removing it. If anything, it should help prevent damage to components that are very sensitive to abuse. The front doesn't do well with flex. Plus I think it will be unsafe on the road, especially on a lifted Pathy. If you ever had to swerve hard to avoid an accident, it's hard to predict that it will handle how it should and who knows what could happen. The rear however can go. I've removed mine permanently and never looked back.Nope haven't put it back on yet...I've gotten used to driving with out it...actually isn't to bad Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
cntryboy_88 Posted July 8, 2016 Author Share Posted July 8, 2016 Well Betsy is gone...been a long process of a lot of different thingso with that r50 but I am definitely excited to have my new project...still don't have a name for her...also I did decide to put my front sway bar back on Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
cntryboy_88 Posted July 10, 2016 Author Share Posted July 10, 2016 Had my rock sliders installed today...next up will be a winch and some bumpers Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
hawairish Posted July 10, 2016 Share Posted July 10, 2016 Where'd you end up welding to? I feel like the attachment tubes may be too long...if the truck were to rest on the outermost rail, that's a lot of leverage at the mounting point. If it doesn't cause damage there, it seems like it could pin up against the rocker panel, no? Link to comment Share on other sites More sharing options...
cntryboy_88 Posted July 10, 2016 Author Share Posted July 10, 2016 Yep cut the attachment tunes down then used angle iron and welded that to the frame then the attachment tube to the angle iron Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
cntryboy_88 Posted July 13, 2016 Author Share Posted July 13, 2016 Lots of work today 1st: 102" whip 2nd: new headliner...I did this on Betsy as well as lot easier this time and it looks way better 3rd: door panels...also did this on Betsy 4th: finally covered my storage box Sent from my SM-N920V using Tapatalk 1 Link to comment Share on other sites More sharing options...
mjotrainbrain Posted July 13, 2016 Share Posted July 13, 2016 I really like what you did with the headliner! Just for future reference, what did you use for material? Link to comment Share on other sites More sharing options...
cntryboy_88 Posted July 13, 2016 Author Share Posted July 13, 2016 Went to joann fabric as gay as that sounds and bought 5 yards...their website had a 40% off coupon so that helped Sent from my SM-N920V using Tapatalk 2 Link to comment Share on other sites More sharing options...
cntryboy_88 Posted July 25, 2016 Author Share Posted July 25, 2016 Quite being lazy today and finally decided to stop the tire rub with the 33's...trimmed a lot of plastic and a little bit of metal...corrected most of the issues have a little bit of work left in the drivers side Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
cntryboy_88 Posted August 7, 2016 Author Share Posted August 7, 2016 YETI!!! That's the name I finally decided on the other day Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
mjotrainbrain Posted August 8, 2016 Share Posted August 8, 2016 Yeit is a pretty good name! Works perfect with the paint color. Will it be getting any cool stickers to match the name? Link to comment Share on other sites More sharing options...
cntryboy_88 Posted August 9, 2016 Author Share Posted August 9, 2016 Yeit is a pretty good name! Works perfect with the paint color. Will it be getting any cool stickers to match the name? I need to get a sticker never thought of that but now I'm definitely going to Sent from Yeti! 1 Link to comment Share on other sites More sharing options...
