Pklambooy Posted December 5, 2015 Share Posted December 5, 2015 Neither rear door opens from inside or outside. I can hear the locking mechanism working. Child lock is off. Door handles feel right. If it was one door I say something needs repairing, but both doors can't be councidence. Not familiar with Pathfinders but tnis would be a safety issue if one can't open doors???? Link to comment Share on other sites More sharing options...
hawairish Posted December 7, 2015 Share Posted December 7, 2015 Lube it? http://www.nissanpathfinders.net/forum/topic/40922-rear-passenger-door-wont-open-on-my-98-pathy Link to comment Share on other sites More sharing options...
anyexcuse Posted December 13, 2015 Share Posted December 13, 2015 Please try this, it worked for me. Had the same problem with a '99 Pathfinder. Took Bob's suggestion and pounded (gently) with a rubber mallet on the outside door handle, but before I did that, I sprayed Kroll rust buster/lubricant into the handle openings when the handle was fully opened. The handle had no resistance before the procedure and just kind of flipped opened and closed. As I was tapping, slight resistance began to be felt at the full opening position of the handle. I continued to close the handle, tap some more, open the handle and get a bit more contact/resistance as I proceeded. After about 10 minutes of tapping, pulling open, spraying some more, closing and tapping again, getting a bit more resistance at full opening each time, I tapped the handle closed again and tried to open the door from the inside....Voila, she popped open. Link to comment Share on other sites More sharing options...
