maddmark1981 Posted November 27, 2015 Share Posted November 27, 2015 Ok fellas and felletts, yes winter is here and is my utmost favorite time of year, I long to trail ride in the white icy cold Nova Scotia snow and am always prepared for pulling out random strangers and offering a boost when needed... Things I need to do include my heater, she's slow and only blows out of a couple ports on the floor, I also heard a noise which sounded like a business card caught in a fan blade... I need to address this straight away, any tips, tricks or advice is duly appreciated. Sent from my MotoG3 using Tapatalk Link to comment Share on other sites More sharing options...
5523Pathfinder Posted November 27, 2015 Share Posted November 27, 2015 http://www.nissanpathfinders.net/forum/topic/7466-how-to-prevent-fire-clean-blower-resistors/ 1 Link to comment Share on other sites More sharing options...
adamzan Posted November 27, 2015 Share Posted November 27, 2015 Take the blower motor out. There's leaves and @!*% in there. Also replace your thermostat, get the 180F one. The stock 170f is too cold for here. If they don't list it, ask for an 02 xterra thermostat. Trust me. The heat sucks with the 170F stat. Sent from my SGH-I747M using Tapatalk 1 Link to comment Share on other sites More sharing options...
maddmark1981 Posted November 27, 2015 Author Share Posted November 27, 2015 Thanks guys, I figured it might be plugged up with something, I'm going to check it out this weekend Sent from my MotoG3 using Tapatalk Link to comment Share on other sites More sharing options...
Terranovation Posted November 27, 2015 Share Posted November 27, 2015 The blower is held in with three 8mm? screws I believe, then you can undo the mouse wheel and clean it. I used degreaser and an old toothbrush to clean all the fins on it, rinse off with warm water and towel dry be careful not to break the fins. Remove your glove box and behind that you'll unscrew a metal plate. Behind that you can remove the resistor and vacuum out the crud in the evap box but beware of nasty stuff like spiders and bitey things. Link to comment Share on other sites More sharing options...
Slartibartfast Posted November 30, 2015 Share Posted November 30, 2015 It is amazing how much noise a single leaf caught in that squirrel cage fan will make. It is also amazing how much of a mess you can make if you run the fan with the resistor pack out before vacuuming out the leaves. Cleaning it out should deal with the air flow and the noise, but I'm not as sure about it coming out the bottom vents only. That sounds more like the vent doors not working properly. Do you have the pushbutton climate control or the levers? Link to comment Share on other sites More sharing options...
maddmark1981 Posted December 13, 2015 Author Share Posted December 13, 2015 Levers, Slartibartfast I cleaned out the crud in the evap box behind my glove box but where's the blower located? Sent from my MotoG3 using Tapatalk Link to comment Share on other sites More sharing options...
5523Pathfinder Posted December 13, 2015 Share Posted December 13, 2015 The blower is to the right of the resistor, screws and connector are underneath. 1 Link to comment Share on other sites More sharing options...
maddmark1981 Posted December 17, 2015 Author Share Posted December 17, 2015 Thank you Sent from my MotoG3 using Tapatalk Link to comment Share on other sites More sharing options...
Blue109 Posted December 17, 2015 Share Posted December 17, 2015 I need this now! Link to comment Share on other sites More sharing options...
Slartibartfast Posted December 17, 2015 Share Posted December 17, 2015 Alright, good, much less to go wrong with levers. Hopefully cleaning it out deals with the problem, but if not, you may need to pull that assembly and check that the levers are still hooked up properly. If that's all working right and there's still no heat out the defrost vents, you may need to pull the dash and make sure the other end of the cable is hooked up properly. Hopefully it doesn't come to that. Link to comment Share on other sites More sharing options...
