TheRadBaron Posted November 1, 2015 Share Posted November 1, 2015 After fixing the coolant temperature sender that was causing my '87 SE to run poorly everything was great and I was loving life for a few days. Then my fuel pump fuse started blowing. It was on a really rainy night and I had to trailer the PF home. I first thought that it was the fuel pump but after doing some research on here it seems that it's likely the sending unit shorting out. I found this thread http://www.nissanpathfinders.net/forum/topic/27467-fuel-pump-fuse-blowing/ where the problem is discussed and it's the EXACT problem that I'm having. GrimGreg posted a few links to courtesyparts.com for the parts. One is the entire fuel pump assembly that incudes the cap/sender part, and the other is just for the cap/sender. I think that I want to buy the cap/sender assembly that's listed as part# B5060-41G01 for $195. There isn't a picture shown so I wanted to make sure that this part is indeed what I want before ordering it. I'm looking for the metal cap with the wires that go through the plastic caps to the fuel pump and sending unit. Also, isn't there a member here who can get good prices on factory Nissan parts? Can someone steer me in his direction. Thanks. Link to comment Share on other sites More sharing options...
amo1dun Posted November 17, 2015 Share Posted November 17, 2015 its the sending unit bud. i created that thread a while back. its not the pump...go grab a junkyard sender ifound mine on craigslist...guy was parting out a 91...although part numbers for 87-89 and 90-95 senders are different i can confirm thay a 91 sender will work in the 89 cheers! Link to comment Share on other sites More sharing options...
