maddmark1981 Posted November 1, 2015 Share Posted November 1, 2015 I just want to give a big shout out to all the guys and gals on here willing to help, to be honest I believe our objective as humans is to help one another and return the favor pass it on, pay it forward hommies. Ahhahaha And then the squeeling noise which I knew it was in the belt system, so I was at the Canadian tire gas station in Moncton and the lube of choice was 80-w90 gear oil ... While it was off I put the oil in the front and back of all the pullies.. Once I started it it went away, but I looked and seen the lowest pully seemed to have a bit of a wobble , should these be replaced right away ? Sent from my MotoG3 using Tapatalk Link to comment Share on other sites More sharing options...
RF600 Posted November 21, 2015 Share Posted November 21, 2015 I know this is old, is it fixed? If not try the idler pulley bearing. 1 Link to comment Share on other sites More sharing options...
maddmark1981 Posted November 22, 2015 Author Share Posted November 22, 2015 Ok, cool thanks... What I did was put a little gear oil on each one on that very day and it has not been back since... Sent from my MotoG3 using Tapatalk Link to comment Share on other sites More sharing options...
RF600 Posted November 25, 2015 Share Posted November 25, 2015 The idler pulley bearing is sealed. It's best to replace it. 1 Link to comment Share on other sites More sharing options...
Slartibartfast Posted November 25, 2015 Share Posted November 25, 2015 You say the lowest pulley had a bit of wobble? That's the harmonic balancer, and there's a rubber layer in there that's supposed to dampen vibrations or something. When it lets go, the pulley can get misaligned or shift around. This would cause misalignment and belt noise, and if the outer part manages to walk forward, it could make friends with your radiator. 1 Link to comment Share on other sites More sharing options...
adamzan Posted November 25, 2015 Share Posted November 25, 2015 That's less of an issue on the WD21, more on the r50, with the one piece balancer. Mine looks wobbly at idle too. But as soon as you give it any throttle it smooths out... Link to comment Share on other sites More sharing options...
