BuffaloR50 Posted December 10, 2015 Author Share Posted December 10, 2015 Ok well my driveshaft had been ground down on the ends to accommodate a grease fitting for aftermarket ujoints. So I thought that was the problem for sure. I replaced the drive shaft with one from the junkyard and the vibration is exactly the same. Nothing changed what else could my issue be?? Next step is front lower control arm bushings, sway bar endlinks, an alignment and tire balancing. Sent from my SM-G900V using Tapatalk Link to comment Share on other sites More sharing options...
