DTP511 Posted July 20, 2015 Share Posted July 20, 2015 (edited) My 88 project has me stumped. Can't pull the speedo cable down from the transmission side...can't pull it through from the top. Any clues? HELP! Edited July 20, 2015 by DTP511 Link to comment Share on other sites More sharing options...
MY1PATH Posted July 21, 2015 Share Posted July 21, 2015 It screws into the speed o gear at the T-case. It only needs to be hand tight but there are flats on the nut to break it loose with a wrench.It follows the frame rail forward and crosses over the bell housing, there are folded over metal tabs that go through the bell housing bolts that hold it in place and keep it from falling on the exhaust.The top end bolts to the firewall with two (10 mm hex cap?) screws. Link to comment Share on other sites More sharing options...
