beachbum101 Posted June 16, 2015 Share Posted June 16, 2015 Hi guys, I've noticed that I have a small amout of oil weaping out of the back of the alternator. I've figured that is the vacuum pump on the rear of the alternator I assume the oil is there for lubrication. Ive read that theres a pair of o-rings in there and is it possible they've gone or could the banjo bolts be leaking? I'm heading off on a 3000km road trip in a couple of weeks so I just wanna be sure everythings ready to go. Also any road trip preps you'd reccomend? Cheers guys Link to comment Share on other sites More sharing options...
SpecialWarr Posted June 16, 2015 Share Posted June 16, 2015 Ahhh.... is that a 2.7? I ask because I've changed my alternator and there are three bolts, two electrical connections and one belt.... no oil on a 3.0 v6 alternator. Since I have worked with banjo bolts a lot I know a good seal is very important ( I've been covered in hydraulic fluid more than once because I didn't confirm that the seals were good ). If you've moved the banjo bolts at all there is a chance that the seals are broken. Link to comment Share on other sites More sharing options...
beachbum101 Posted June 17, 2015 Author Share Posted June 17, 2015 Yeah its a 2.7. I havent moved any of the fittings or moved the fittings, although after looking at it last night I am starting to think that the leak is coming from the seal. Maybe vibrations from the engine? I dunno. Maybe time to reseat the connection or new lines are in order cheers special Link to comment Share on other sites More sharing options...
