CDN_S4 Posted June 6, 2015 Share Posted June 6, 2015 I finally pulled the trigger on an Xterra 3.3 air intake. Not sure yet how the fitment will be, but it's the same motor, so it SHOULD fit!? If not I'm sure it can be made to fit. Upon closer inspection I noticed that the OEM intake is actually a whole lot more complicated than initially expected. First off, there is a thin hose that runs from behind the air box into a metal hose. Then there is a chamber below the main tubing, I suspect for water separation?! There are quite a few things going into and coming out of this system. So I was wondering for those that have replaced their oem intakes, can a bunch of these things be bypassed by installing a simple straight forward tube and filter? Pics to follow. Thanks Link to comment Share on other sites More sharing options...
clkindred Posted June 7, 2015 Share Posted June 7, 2015 All the hoses (the big ones are PCV and idle air control valve I think) and the smaller one (not sure what that one is) I just routed into the pipe, seems to work fine. 3 Link to comment Share on other sites More sharing options...
thorpe991 Posted June 9, 2015 Share Posted June 9, 2015 this is mine but i ended up reruning it but i dont have a pic of the new way Sent from my LGLS990 using Tapatalk 1 Link to comment Share on other sites More sharing options...
CDN_S4 Posted June 9, 2015 Author Share Posted June 9, 2015 Did you guys notice any difference? Link to comment Share on other sites More sharing options...
clkindred Posted June 12, 2015 Share Posted June 12, 2015 Performance? Hard to say, it did not hurt though. It SOUNDS like it helped performance just because the extra noise that can make it out of the intake. I do like the way it sounded after doing it. Link to comment Share on other sites More sharing options...
thorpe991 Posted June 12, 2015 Share Posted June 12, 2015 Yeah i gained maybe 1mpg or 2mpg and a lil power. I also did a more open exhaust and a throttle body spacer. But it does sound pretty ba when i hammer on it Dont do a throttle body spacer it didnt help much of anything i just got a good deal on the one i have Sent from my LGLS990 using Tapatalk Link to comment Share on other sites More sharing options...
CDN_S4 Posted June 13, 2015 Author Share Posted June 13, 2015 Thanks. My main motivation was to get rid of my busted air box hanging down by the tire, sucking in all sorts of water. More throaty sound is always welcome! Link to comment Share on other sites More sharing options...
fixinto Posted June 13, 2015 Share Posted June 13, 2015 the small "box" under the intake piping is to reduce noise during the air intake. I have been thinking about a straight shot setup to just increase efficiency of air intake. But right now, the top of the list is the clutch. Link to comment Share on other sites More sharing options...
CDN_S4 Posted June 13, 2015 Author Share Posted June 13, 2015 Bought a $95 Xterra intake from eBay. Didn't use all the parts supplied but it contained everything I needed to build mine and reconnect every hose as before. Link to comment Share on other sites More sharing options...
CDN_S4 Posted June 13, 2015 Author Share Posted June 13, 2015 And the best part about it....it made my SES light go away!!!! Link to comment Share on other sites More sharing options...
