My new 2001 LE 4x4
  • Please log in to reply
278 replies to this topic
#261 ONLINE   hawairish
hawairish
  • Members
  • PipPipPipPipPip
  • 1,841 posts
  • Local time: 06:46 AM
  • Country:
  • Model:SE
  • Year:2004
Posted 29 June 2017 - 10:43 AM
Good point!
#262 OFFLINE   TowndawgR50
TowndawgR50
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 573 posts
  • Local time: 07:46 AM
  • Country:
  • Model:LE
  • Year:2001
Posted 09 October 2017 - 07:14 PM
So after almost a year the front drivers side bearing set has gone bad again. That makes 2.5 complete sets since ive owned the truck but I think I finally found the issue. From what I can tell, the flaw lies in the design of the inner bearing grease seal. The spring has a small lip that keeps it in place and if that lip fails or gets damaged the spring unseats and allows debris to get in. I bought the "National" brand bearings and seals with the 3 year warranty from Orielly's because I figured I would replace them before the 3rd year was up and have bearings for the life of the truck but this clearly is a problem. Poor quality materials? Maybe but it very well might be that these seals are fine under normal conditions. The terrain up here has been rough. Lots of sandy mud, water crossings, snow and icy roads that were salted. Could have made things worse or caused the problems all together. We'll see how long these last. Wish I had taken a photo of the damaged unit.
Has anyone else had chronic wheel bearing/seal issues?
 I also gave up on the crap hardware that came with my Warn manual hubs. The 2nd stud to break while taking off the assembly this time was the last straw. Ive broken 2 on the passenger side as well over the past year.
I went for some stainless A2-70 SHCS's and yanked everything while I had the hub out. Have some 10.9's coming but these are all I could find today.
Of course one was broke down in the bore so that required some effort. Milled a flat and pulled it out with a left handed drill. Tapped them all and called it good. They're M8x1.25 if anyone is interested.
#263 OFFLINE   Citron
Citron
  • Members
  • PipPipPipPipPip
  • 962 posts
  • Country:
  • Model:SE
  • Year:1992
Posted 09 October 2017 - 08:18 PM
Are those double lip seals? If not, give that a try. McGuire Bearing should be able to find those seals in a double lip configuration. They have a store in Tacoma, don't know if they have one in your area.
#264 OFFLINE   Slartibartfast
Slartibartfast
  • Members
  • PipPipPipPipPip
  • 4,743 posts
  • Country:
  • Model:SE
  • Year:1993
Posted 09 October 2017 - 10:12 PM
How's the surface the seal rides on?
#265 OFFLINE   TowndawgR50
TowndawgR50
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 573 posts
  • Country:
  • Model:LE
  • Year:2001
Posted 09 October 2017 - 11:02 PM
Citron-
 I believe they are. There is an inner lip and outer. The inner lip is the one with the spring, the outer more of a wiper than anything. I'll have to call them and see what they offer.
Slartibartfast-
Spindle surface is good. That was my original thought, that something like sand or a rock got in a galled it up but its unscathed.
#266 OFFLINE   Alexey_Maruschak
Alexey_Maruschak
  • Members
  • Pip
  • 24 posts
  • Local time: 06:46 PM
  • Country:
  • Model:LE
  • Year:2001
Posted 12 November 2017 - 02:38 PM
Be healthy!
I can assume there are two possible causes of your problem:
1) you have an elevator, and the wheels are significantly different from the standard size.
And after the elevator body and the suspension lift, did you a) carry out the selection of the take-off axis on the disks with the new rubber, select the zero point on the descent-camber axes B) did you work at the descent-and-collapse stand after the elevator and the wheels change at the service station your car?
Here you can check whether the standard axis of the demolition is aligned with your new tires and disks for grip (point 0): https://www.wheel-size.com/calc/
To specify OEM parameters, specify the parameters indicated on the rating plate of the driver's license plate number. As a rule, for the R50 with the VK35DE engine - this is for tires 255 / 65-16, and the size of the regular drive - r16 departure of the standard drive ET 30, the width of the disk is 7 inches. Do you know what size of wheels you have in centimeters, what sort of flight in the new drive along the axis and at the spacer of the hub, if it is?
2) Factory manual on repair and maintenance R50 assumes a tightening of bearings of a nave a nut of fastening with the certain effort. The tightening of the nut is done with a special key KV4015400 with a force of 79-98 Nm,
Your hub, after replacing the inner and outer bearing was tightened according to the rules of the plant?
Such a key, for hub bearings, I made this by myself.
However, I have not figured out how to upload a photo of my work on this site.
Therefore, I simply give a link to my on-board journal on the second answer: https://www.drive2.r...82137761644818/
#267 OFFLINE   Alexey_Maruschak
Alexey_Maruschak
  • Members
  • Pip
  • 24 posts
  • Country:
  • Model:LE
  • Year:2001
Posted 12 November 2017 - 02:58 PM
Here is my example, from the journal of my pathfinder, the adjustment of the bearing preload of the hub bearing using a special key, which was referred to from above. https://www.drive2.r...19521156989393/
Does not want this site to upload my photos, sorry. I can not figure out what's wrong.
But as I wrote your problem is likely not only in the pre-tension, nor in the absence of the collapse and convergence of the front suspension.
#268 OFFLINE   ChemExposure
ChemExposure
  • Members
  • PipPip
  • 52 posts
  • Country:
  • Model:SE
  • Year:2001
Posted 12 November 2017 - 09:12 PM
The guys at O'reillys may have given you a rear wheel seal. The ones for the front should have an extra lip on them to prevent it from going too far into the hub.
The guys at Canadian tire pulled the same thing on me, I installed mine anyways and as I was pressing it in the metal retainer spring snapped like yours. I took the one off my old seal put it on and called it a day.
https://www.autopart...l/pagenum1/tabs
Those are the correct ones that match the OEM seals.
#269 OFFLINE   TowndawgR50
TowndawgR50
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 573 posts
  • Country:
  • Model:LE
  • Year:2001
Posted 24 February 2018 - 11:32 PM
Finally getting around to a bunch of changes. Trying out 6" of lift before I look into alternatives. Front cross member has been a snag for lots of the trails this past year.
 Installed LR rears and spacers aiming for 6" of lift. Forgot to record my height prior to installing and dont have a reference number. Can anyone running 33's and 6" lift give me a fender height measurement?
#270 OFFLINE   TowndawgR50
TowndawgR50
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 573 posts
  • Country:
  • Model:LE
  • Year:2001
Posted 06 May 2018 - 07:33 PM
Did a check of the new rear end hardware. Passenger side adjustable trailing arm needed tightening. I also want to lengthen my bump stops to keep the tires from tucking too much. There is a little bit of noise that was present before the lift, assuming its U-joints but not sure, but its a mild throttle on/off related clunk. Pinion angle is good so I dont think its the rear end but I cant rule that out. Other than that so far so good with the new 6" setup.
#271 OFFLINE   TowndawgR50
TowndawgR50
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 573 posts
  • Country:
  • Model:LE
  • Year:2001
Posted 26 May 2018 - 08:30 AM
Had a great weekend working with the US Forest Service for the annual trail clearing event at Liberty. Wheeling and working, at least for me, is super fun. This year our club was assigned the eastern side of the region. Rained on Sunday morning making for some very muddy sections and zero trail dust which is really nice when there are lots of rigs.
#272 OFFLINE   TowndawgR50
TowndawgR50
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 573 posts
  • Country:
  • Model:LE
  • Year:2001
Posted 26 May 2018 - 08:41 AM
Winching the larger logs out of the way
The rain Sunday morning made a really deep 90 degree drop off at a creek crossing that caused some damage to my swing-out tire carrier. I came off the ledge and landed on my hitch then the rear mounted 33". The weight of the truck was resting on the 33 and the only damage was minimal considering all the load on it. The lower mount had the rear facing rivnut pulled out slightly and the passenger side shoved in. Not really that bad but there is room for improvement. Would this have happened to a factory equipped rig? Hard to say. I think damage would have been sustained but not as bad. I'll pull it soon, fix the body and reinforce the panel.
#273 OFFLINE   TowndawgR50
TowndawgR50
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 573 posts
  • Country:
  • Model:LE
  • Year:2001
Posted 26 May 2018 - 09:10 AM
#274 OFFLINE   TowndawgR50
TowndawgR50
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 573 posts
  • Country:
  • Model:LE
  • Year:2001
Posted 26 May 2018 - 09:11 AM
#275 OFFLINE   jjonez
jjonez
  • Members
  • PipPipPip
  • 108 posts
  • Country:
  • Model:SE
  • Year:2002
Posted 28 May 2018 - 03:55 PM
Hahaha from the pictures I thought the X90 was a NB Miata! I really like that LWB samurai too
Bummer about your carrier. What's your plan for fixing/reinforcing?
#276 OFFLINE   TowndawgR50
TowndawgR50
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 573 posts
  • Country:
  • Model:LE
  • Year:2001
Posted 28 May 2018 - 08:23 PM
I had never heard of or seen either of those Suzuki models prior to moving up here. Both really capable and unique little rigs.
 Id like to make a large plate or block to place behind the carrier mounts to help spread the load as well as to tie into the rest of the internal structure. Maybe even see if I cant just grab a cut off a junkyard rig and weld that in.
#277 OFFLINE   RainGoat
RainGoat
  • Members
  • PipPipPipPip
  • 209 posts
  • Country:
  • Model:LE
  • Year:2002
Posted 13 June 2018 - 11:33 AM
Sounds like the perfect time to do two....
#278 OFFLINE   RainGoat
RainGoat
  • Members
  • PipPipPipPip
  • 209 posts
  • Country:
  • Model:LE
  • Year:2002
Posted 13 June 2018 - 11:34 AM
#279 OFFLINE   TowndawgR50
TowndawgR50
  • Topic Starter
  • Members
  • PipPipPipPipPip
  • 573 posts
  • Country:
  • Model:LE
  • Year:2001
Posted 14 June 2018 - 04:53 AM
Just might be...
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
