Trogdor636 Posted May 10, 2015 Share Posted May 10, 2015 What's up party people? Been forever since I've been here.... I'm installing UCA poly bushings with no good instructions....should the outer lip of the bushing be on the outside of the UCA on both sides? Or should it look as if you used the press in bushings....anybody have a good picture of theirs? Thanks! Link to comment Share on other sites More sharing options...
SkiBumBrian Posted May 11, 2015 Share Posted May 11, 2015 Good to hear from you! Sorry I can help you with your issue but I am sure someone will chime in... I was wondering if you moved north or not. Link to comment Share on other sites More sharing options...
adamzan Posted May 11, 2015 Share Posted May 11, 2015 http://www.nicoclub.com/archives/nissan-hardbody-truck-suspension-torsion-bars-bushings.html It's for a 2wd but the uca are the same. You do want the flange part on the outside on both sides. It's fairly easy, I was able to push in my poly bushings by hand. Make sure to use a grease made for it or you'll be replacing them again in a short period of time. 1 Link to comment Share on other sites More sharing options...
5523Pathfinder Posted May 11, 2015 Share Posted May 11, 2015 Here's a shot of mine... Link to comment Share on other sites More sharing options...
Trogdor636 Posted May 11, 2015 Author Share Posted May 11, 2015 Thanks guys, that helped. It seemed like the proper way, Prothane sent me instructions for a leaf spring..... I did use a ton of their "super grease" I know how noisy my sway bar bushings get....Thanks again. Link to comment Share on other sites More sharing options...
