I_love_my_95_pathy Posted April 19, 2015 Share Posted April 19, 2015 Hi guys so I'm new here. I've owned my 1995 Pathfinder LE for 6 years now and about 2 years ago my a/c stopped working. I've done everything I can think of but nothing seems to work. Ok but here's my problem the a/c light turns on inside the vehicle but the clutch won't cycle. I've given it direst power with an alligator clip and it will cycle but as soon I plug it in it stops. I've checked the relay that seems fine. I haven't found a fuse but then again I don't have any fuse box covers. If you guys have any pics of the covers it will be greatly appreciated. I'm still new so I'll work on getting pics and vids on here. Just wanted to thank you guys for reading this and any help you will give Link to comment Share on other sites More sharing options...
adamzan Posted April 19, 2015 Share Posted April 19, 2015 That means its low on refrigerant. You need to get it recharged. You can get it from AutoZone or something and diy but make sure not to overcharge It. Link to comment Share on other sites More sharing options...
I_love_my_95_pathy Posted April 19, 2015 Author Share Posted April 19, 2015 Hey adamzan for the reply ill give that a try later today and get back to you I could reply use some a/c Link to comment Share on other sites More sharing options...
adamzan Posted April 19, 2015 Share Posted April 19, 2015 You probably have a leak somewhere. So if there is 0 psi i would try and listen for it. You can also get dye to put in and it will show leaks under a black light. I repllaced all the o rings on mine and that solved the issue. 1 Link to comment Share on other sites More sharing options...
I_love_my_95_pathy Posted April 19, 2015 Author Share Posted April 19, 2015 Thanks if refilling it doesnt work then ill try doing that Link to comment Share on other sites More sharing options...
Pav Posted April 19, 2015 Share Posted April 19, 2015 I have had the same problem. Adamzan's advice is best. You want to check out the seals first. It is a 20 year old A/C system after all. You can get a $5 set from any auto parts store. Replace those first and then add your refrigerant in a can. You can get it working with just injecting more but it will leak and be back at square one pretty quickly. Thanks if refilling it doesnt work then ill try doing that Link to comment Share on other sites More sharing options...
I_love_my_95_pathy Posted April 20, 2015 Author Share Posted April 20, 2015 Ok so looks like o-rings your time is up. Thanks guys I'll get to it on Tuesday. I'll let you know how it goes Link to comment Share on other sites More sharing options...
k9sar Posted April 20, 2015 Share Posted April 20, 2015 My AC is always working.... sometimes it just means Air Circulation when I open the windows Link to comment Share on other sites More sharing options...
I_love_my_95_pathy Posted April 21, 2015 Author Share Posted April 21, 2015 K9sar that's what I've been using but with a newborn that's not always good enough Link to comment Share on other sites More sharing options...
adamzan Posted April 21, 2015 Share Posted April 21, 2015 I wonder how the rest of us survived growing up, no a/c, or airbags in cars. It's a miracle we're even alive! No offense to you, just a general observation... Link to comment Share on other sites More sharing options...
k9sar Posted April 21, 2015 Share Posted April 21, 2015 well then I would definitely do the o-ring thing then add a leak detector to the system and see if there is anywhere else your refrigerant is going Link to comment Share on other sites More sharing options...
I_love_my_95_pathy Posted April 24, 2015 Author Share Posted April 24, 2015 Ok so update I have done half of the o-rings on the system and then the strangest thing happens the refrigerant/oil/leak finder that I was adding to the system started spilling out the lowside port. Hey adamzan did that happen to you when you did your seals? Link to comment Share on other sites More sharing options...
adamzan Posted April 24, 2015 Share Posted April 24, 2015 Low side port? You mean where you add the refrigerant? You may have a problem with the schrader valve inside the port. Could be stuck down, or maybe it's loose (I think you can tighten them like a tire valve). Link to comment Share on other sites More sharing options...
I_love_my_95_pathy Posted April 24, 2015 Author Share Posted April 24, 2015 Ya its called the the low side port and it was loose Link to comment Share on other sites More sharing options...
