Angelmen Posted April 17, 2015 Share Posted April 17, 2015 Is this mean the egr is bad or something els that has to do with the egr .? Link to comment Share on other sites More sharing options...
WD21colorado Posted April 17, 2015 Share Posted April 17, 2015 is it code 32 or 23? because the DTC code of 23 is idle switch and code 32 is egr function, Link to comment Share on other sites More sharing options...
Angelmen Posted April 17, 2015 Author Share Posted April 17, 2015 It's 23 that's what it gave me . Link to comment Share on other sites More sharing options...
Angelmen Posted April 17, 2015 Author Share Posted April 17, 2015 Sorry it's 32 Link to comment Share on other sites More sharing options...
Angelmen Posted April 17, 2015 Author Share Posted April 17, 2015 That's what the ecu gave me . So it has something to do with the egr right . I look at it all the hoses are in good condition . Link to comment Share on other sites More sharing options...
WD21colorado Posted April 17, 2015 Share Posted April 17, 2015 yes the EGR control your nox output. by re diverting the exhaust gas's back into the combustion chamber, you want to make sure the egr valve still works by putting vacuum pressure on the egr vacuum line. and feel if the diaphragm moves. if it doesn't move then the egr is bad. My vehicle is also throwing the same code and found out the wiring harness that controls the vacuum solenoid and has an intermittent fault. you might also want to check you vacuum lines that run to the egr valve and make sure they dont have a leak. Link to comment Share on other sites More sharing options...
Angelmen Posted April 18, 2015 Author Share Posted April 18, 2015 Ok I'll try to do all that thanks . Link to comment Share on other sites More sharing options...
ebayfish Posted April 18, 2015 Share Posted April 18, 2015 I had a bad miss & threw this code. Its an easy one to get the egr off & scrape clean. Just make sure to get a new egr gasket to reinstall. 2 Link to comment Share on other sites More sharing options...
Angelmen Posted April 18, 2015 Author Share Posted April 18, 2015 I took it off cleand it and I reset the ecu . And it came back so now I'm going to do the solenoid see what happens . Link to comment Share on other sites More sharing options...
Precise1 Posted April 20, 2015 Share Posted April 20, 2015 Check the EGR tube as well, they can build up and clog as well... B Link to comment Share on other sites More sharing options...
k9sar Posted April 20, 2015 Share Posted April 20, 2015 my EGR valve was clogged with mud one time and threw a code. Link to comment Share on other sites More sharing options...
Precise1 Posted April 20, 2015 Share Posted April 20, 2015 That is quite the euphemism! B Link to comment Share on other sites More sharing options...
Angelmen Posted April 23, 2015 Author Share Posted April 23, 2015 Well I check all and now it gave me a code # 55 ? Link to comment Share on other sites More sharing options...
Precise1 Posted April 23, 2015 Share Posted April 23, 2015 Code 55 is All Clear, looks like you fixed it! B Link to comment Share on other sites More sharing options...
Angelmen Posted April 23, 2015 Author Share Posted April 23, 2015 Well that's what I tough but it came back on I'm baffled ? Link to comment Share on other sites More sharing options...
Slartibartfast Posted April 25, 2015 Share Posted April 25, 2015 That means there's still a problem. This means the computer didn't immediately see the issue, but discovered it when it tried to actuate the valve or after the system warmed up. The FSM has a diagnostic procedure starting on page 93 of the EF&EC section for diagnosing your code. Link to comment Share on other sites More sharing options...
Angelmen Posted April 27, 2015 Author Share Posted April 27, 2015 I try it again has not turd on , so I think I fix it Link to comment Share on other sites More sharing options...
