Rear Brake Hubs
brc19761
My 1994 Nissan Pathfinder LE has four wheel disk brake pads. I also have a 1997 D21 (Hardbody) four wheel drive with rear brake shoes. My question is about the brake shoes on the 4x4 Hardbody. I was wondering what size bolts does it take to get the rear hub off on the Nissan Pathfinder/D21 4x4. The rear hubs have two threaded holes in which you place a certain size bolt to remove the hub. I just need to know what size bolt to use. It seems I have forgotten :).
Thanks,
brc
1997 was the last year they made the Hardbody (D21) truck. The 1997 truck is the same as the 94-95 Pathfinders except it comes with a driver's side airbag. Pathfinders changed in 1996 like you said, but in 1998 the Hardbody truck became the Frontier.
Thanks for the reply.
brc
