tran issues
Rusty53
Hello to everyone. Glad to have found this forum. I'm a socket set mechanic with little knowledge of transmissions. Was driving my 95 SE on the highway at 60 mph in -30 degree weather and started having tran problems. Its manual 5 speed 4 wheel Will only engage in 4th gear now and clutch chatters when try to engage in other gears. I'm assuming of course tranny is gone but if anybody has any other suggestions(wishful thinking maybe) would appreciate to hear Thanks, Rusty
You may be right but it might also be throw out bearing, pressure plate, friction plate issues. You have to pull the tranny either way but it might not be as bad as it seems. How does the pedal feel when you engage the clutch? You say it only engages in 4th now. Is that running or just sitting in the driveway? Does it move at all? If the pedal feels good, It engages fine in 4th while running but no other gear, yes, you probably have deeper issues.
