DsR50 Posted August 9, 2014 Share Posted August 9, 2014 Ok so I pulled the heads from another pathfinder but am unsure of the year but I'm pretty sure it was in the 90-95. I've already installed them and just found that the way the distributor mounting is a little different. I can make a little bracket to make it work but I want to know if I might be missing a bracket from the donor or if I might be missing a bracket from the donor or if that distributor from the donor would work on my 93 Link to comment Share on other sites More sharing options...
DsR50 Posted August 11, 2014 Author Share Posted August 11, 2014 bump Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 11, 2014 Share Posted August 11, 2014 I don't know anything about distributor differences in WD21s. Pics? Link to comment Share on other sites More sharing options...
nunya Posted August 11, 2014 Share Posted August 11, 2014 There's a plate that bolts to the head (2 bolts iirc) that the distributor actually bolts to and has the correct angle for the distributor mout (mpfi and TBI have different distributors and use different mounting plates, I had to change mine when I swapped from TBI to mpfi style). Do you have this plate? I'll look to see if I have a pic of one (I know I have spares somewhere from pulling enough spare dizzys) Link to comment Share on other sites More sharing options...
Nefarious Posted August 12, 2014 Share Posted August 12, 2014 This guy is exactly correct ^. you need to swap the distributor block from your old head over. Link to comment Share on other sites More sharing options...
