gpurdum
removing transfer case shifter
Installing a new clutch and I have seen a few tutorials that say remove transfer shifter but don’t say how.
Do you unbolt it fro side of tranny or there something under boot . Sorry my eyes ain't what they used to be and can't see how it comes off. I could wait till tranny is down on the jack but hate to pull on wrenches when its balanced on the jack
thanks
greg
I just removed the knob and the boot, It is screwed onto the side of the tranny with two bolts and a nut that connect it to the TX
So your talking about the bolts on the control lever bracket I take it. Thanks I didn't want to pull that off and get a shower of ball bearings and springs popping out
Greg
Let me know how it goes, my trans is showing some real bad signs, so i may need to follow closely behind you with some major trans repair.
-Kyle
ferrariowner123 went fine no surprises except that everything worked after I put it back together. only removed two bolts on the control lever bracket to get it out of the way
