mstrofpuppets
AC issues
Hi, I have a 2008 Pathfinder with the V6. Recently the AC has been acting up, it blows cold air but the volume of air coming out of the vents has gone down. I am thinking it's the blower but don't know a ton about these systems. Any help would be appreciated. Thanks!
Not sure why it posted 5 threads but if you have any info please use this one. Thanks!
2011 JKUR, manual trans and some other stuff.....
Have you changed the cabin air filter?
Not for a couple years. Seemed like it was working fine and than it all of sudden stopped putting out as much air.
Pull the filter and look around. Sounds like a obstruction, maybe rodent related. You could also lower the blower motor down and inspect it for debris.
Agreed, I would start there first.
Thanks for the advice, where is the blower located? Is there more than one? Thanks again!
Its under the right side of the dash. Removal of the glove box may be needed. Thats also how you would get to the in-cabin filter.
