DirtyD Posted June 9, 2014 Share Posted June 9, 2014 Hey, I had a quick question, I am in the trying to plan out how I want to lift my pathfinder and I found some coils I might like to get. If im reading it right, it will give me .5" of lift ( 1/2" ) I just want to make sure I am reading this right before I pull the trigger on buying them. https://ruggedrocksoffroad.com/medium-load-50-100-lbs-534-lift-front-springs-pair-nissan-pathfinder-1996-2004-by-old-man-emu-p-3856.html https://ruggedrocksoffroad.com/medium-load-stock-weight-to-gvw-534-rear-lift-springs-pair-nissan-pathfinder-1996-2004-by-old-man-emu-p-3858.html Thanks Link to comment Share on other sites More sharing options...
fleurys Posted June 9, 2014 Share Posted June 9, 2014 You could also lift it using spacers... many have done it before... Have a look here : http://www.4x4design.com/r50-lift-kit.php and here : http://www.4x4design.com/Pathfinder_R50_96-04.php S. Link to comment Share on other sites More sharing options...
DirtyD Posted June 9, 2014 Author Share Posted June 9, 2014 I plan on lifting it with the 2" spacers, but i just want that little extra so i know i won't run and from what i read they help with the ride. Link to comment Share on other sites More sharing options...
Rick13 Posted June 10, 2014 Share Posted June 10, 2014 Hey, I had a quick question, I am in the trying to plan out how I want to lift my pathfinder and I found some coils I might like to get. If im reading it right, it will give me .5" of lift ( 1/2" ) I just want to make sure I am reading this right before I pull the trigger on buying them. https://ruggedrocksoffroad.com/medium-load-50-100-lbs-534-lift-front-springs-pair-nissan-pathfinder-1996-2004-by-old-man-emu-p-3856.html https://ruggedrocksoffroad.com/medium-load-stock-weight-to-gvw-534-rear-lift-springs-pair-nissan-pathfinder-1996-2004-by-old-man-emu-p-3858.html Thanks Yes, clicked on those and that's what I'd think too. Link to comment Share on other sites More sharing options...
Precise1 Posted June 10, 2014 Share Posted June 10, 2014 Yes, those will work fine, many people have installed them. There is nothing wrong with installing spacers like what Fleurys makes, but if your springs are old and worn, you'll just have a taller pathy that still wallows around. Our R50 with almost 180k miles on it has the original suspension and rides/handles like a 1974 Coupe Deville. No way would I put in any spacers, etc without replacing/upgrading the springs; it is just the right way to do it. B Link to comment Share on other sites More sharing options...
Karmann Posted June 10, 2014 Share Posted June 10, 2014 (edited) Those are the exact springs I have, I LOVE their ride. If I were you, I'd get new shocks, buy the coils, and then get a set of the 1" front spacers from Fleurys. Then you have a leveled, controlled ride. And you can look like me Edited June 10, 2014 by Karmann Link to comment Share on other sites More sharing options...
