bwd111 Posted June 3, 2014 Share Posted June 3, 2014 Remove the belt? Been fighting this power steering belt for 2 hours. What bolt needs to be removed/loosen to get the belt off Link to comment Share on other sites More sharing options...
SkiBumBrian Posted June 3, 2014 Share Posted June 3, 2014 Should be a tensioner for each belt. Check out the FSM in the Garage section. Free PDF download has all the info you will need! Link to comment Share on other sites More sharing options...
ahardb0dy Posted June 3, 2014 Share Posted June 3, 2014 (edited) loosen the lock bolt in front, than loosen the bolt accessible thru the pass. inner fender, I use a long extension, you may need to pry the power steering pump away from the block, I use a large pry bar, be careful what you pry against, pic below: Edited June 3, 2014 by ahardb0dy Link to comment Share on other sites More sharing options...
Precise1 Posted June 3, 2014 Share Posted June 3, 2014 Exactly. You will need to loosen the stop bolt, then turn the tensioning bolt counter clockwise quite a bit to get enough play to remove the belt. You may want to use a speed handle or a slow air gun/ratchet/cordless drill. It is a good idea to lubricate the threads first, and you may want to loosen the pivot bolt for the PS unit, depending on movement. Be careful tightening it back up, it is easy to over tension belts with this system. B Link to comment Share on other sites More sharing options...
ThaBigPerm Posted June 3, 2014 Share Posted June 3, 2014 (edited) The big "pivot" bolt is best accessed through the holes in the PS pump pulley (they're there for that reason) - you'll probably have to rotate (or bump over) the engine to get the hole to line up with the bolt. Then, there's a lock not on the adjuster, then the adjuster bolt itself (both below the pump). I've never had to pry on anything to adjust it. Edit: in the diagram above, the adjuster lock nut is indicated by the big arrow. The adjuster bolt is indicated by the "turn" arrow. The anchor/pivot bolt is not indicated, but you can see it behind the PS pump pulley. Edited June 3, 2014 by ThaBigPerm Link to comment Share on other sites More sharing options...
stabworthy Posted June 3, 2014 Share Posted June 3, 2014 i had the same problem . even with the pivot bolt super loose wouldn't move. i remove the pulley with the belt on it , pull bolt out , greased it , put it back by a few turns .... nothing . figured the car gods said no . I stretched the new belt with pulley to shaft, then had a beer. i left the pivot bolt and tensioner bolt loose to see if it loosens , one trail cruise , two burger runs and one spirited run to grocery store , no movement. Link to comment Share on other sites More sharing options...
