Slartibartfast Posted May 21, 2014 Share Posted May 21, 2014 Hello all, I searched but didn't see much about this. My transfer case fluid is a sickly shade of purple, and I'm pretty sure it's not supposed to be, so I'm planning to do something about that tomorrow. I was looking at it today and trying to figure out how I'm going to get the new ATF into the fill hole above the crossmember. The right way would probably be to drive back into town for a pump head and a hose, but I'd rather not if I can avoid it... on the other hand, the best alternative method I can think of involves a turkey baster and a lot of swearing. Anyone found a good trick for filling these buggers? Link to comment Share on other sites More sharing options...
Terranovation Posted May 21, 2014 Share Posted May 21, 2014 There are bottles on the market that already have a plastic tube attached to the cap. They have them on the 1 litre bottles. The tube comes out from the cap and sometimes they put a little plastic lid thing on the end of the tube so you don't, ahem, leak everywhere. Link to comment Share on other sites More sharing options...
Terranovation Posted May 21, 2014 Share Posted May 21, 2014 How about a simple spray bottle? Just fill it up with fluid and you just take the spray part off otherwise it's going to take ages and spray the oil in. Link to comment Share on other sites More sharing options...
adamzan Posted May 21, 2014 Share Posted May 21, 2014 Just go get one of those transfer pumps. Or if you can, attach a long piece of hose to the bottle so you can hold it upside down. Driving to town probably won't hurt the tcase. Its probably been dark for years. Mine was black almost! Link to comment Share on other sites More sharing options...
bushnut Posted May 21, 2014 Share Posted May 21, 2014 if you think thats fun, wait till you change the fluid in the front diff...I ended up using a bottle and hose method with the help of a friend. 1 Link to comment Share on other sites More sharing options...
Steve_RI Posted May 21, 2014 Share Posted May 21, 2014 Just go get one of those transfer pumps. Or if you can, attach a long piece of hose to the bottle so you can hold it upside down. Driving to town probably won't hurt the tcase. Its probably been dark for years. Mine was black almost! Yea, HF sells these transfer pumps cheap and they work well for these tight spaces Link to comment Share on other sites More sharing options...
devonianwalk Posted May 21, 2014 Share Posted May 21, 2014 I use the el'cheapo transfer pump to drain the diffs and the one liter bottle with a twenty four inch length of vacuum hose to refill. It takes time but, it's not really too bad. Link to comment Share on other sites More sharing options...
silverton Posted May 21, 2014 Share Posted May 21, 2014 Just to jump in here, you should be filling the transfer case with gear oil. Also, sickly purple? Sounds like someone might have put Royal Purple in there at some point. Not sure if ATF or gear oil would turn purple from age. Link to comment Share on other sites More sharing options...
Precise1 Posted May 21, 2014 Share Posted May 21, 2014 The FSM states ATF for the later years and gear oil for the earlier years. B Link to comment Share on other sites More sharing options...
Terranovation Posted May 22, 2014 Share Posted May 22, 2014 I've seen an air compressor used to fill up diffs and what not, the guy put a hole in the top of the oil container cap, with 8mm clear tube going into the bottle and going to the fill hole. Then he put a smaller hole into the oil container on the neck of the container. He then connected the air line from the compressor to that hole on the container and the force of the compressed air blew the oil up the tube and into the diff. Took like 4 seconds! Then he connected up the next container, bam done. Job finished in less than two minutes. It was a pretty bad ass way of doing it. 1 Link to comment Share on other sites More sharing options...
SkiBumBrian Posted May 22, 2014 Share Posted May 22, 2014 Here is what I came up with. Worked fine with lung power but if I had to do it again I would put the blower tip on the compressor and try it that way, it sounds much easier unless you like the lightheaded feeling.... 1 Link to comment Share on other sites More sharing options...
Slartibartfast Posted May 22, 2014 Author Share Posted May 22, 2014 Thanks all, the compressor trick sounds like a winner to me. I'll give it a go tomorrow and let you guys know how many quarts I spray on the walls. Link to comment Share on other sites More sharing options...
Precise1 Posted May 22, 2014 Share Posted May 22, 2014 Use a regulator. Another trick is to use a quart bottle that has a nozzle type tip. You can hold it sideways and squirt 1/2 the bottle in at a time by squeezing it. You have to stop and refill a few times, but it will get you there as well without using anything other than what is on hand. B Link to comment Share on other sites More sharing options...
Kingman Posted May 22, 2014 Share Posted May 22, 2014 If you don't have a compressor or are nervous about too much air pressure, a tire works great too. Link to comment Share on other sites More sharing options...
Alkorahil Posted May 22, 2014 Share Posted May 22, 2014 I took a brake bleed kit, reversed the valve and pumped it in for the transfer case and front diff... Link to comment Share on other sites More sharing options...
Slartibartfast Posted May 25, 2014 Author Share Posted May 25, 2014 The fluid is changed, and the walls are not dripping with ATF. Success!I pretty much replicated Brian's design, except I used a plastic rice container (kind of flimsy) and some kind of garden sprinkler hose that was small diameter and didn't flow well. It took a little while but it got the job done. Thanks all for your input!The old fluid came out dark, but not purple. It was winter when I checked it, maybe my finger was turning blue and I hadn't noticed. Link to comment Share on other sites More sharing options...
Terranovation Posted May 25, 2014 Share Posted May 25, 2014 How much fluid came out? I'm thinking about doing mine one day too. Link to comment Share on other sites More sharing options...
Slartibartfast Posted May 26, 2014 Author Share Posted May 26, 2014 I didn't measure the used oil, but the case was still full, and refilling it afterwards took a little under two and a half quarts IIRC. Link to comment Share on other sites More sharing options...
Terranovation Posted May 26, 2014 Share Posted May 26, 2014 Ok thank you Link to comment Share on other sites More sharing options...
