UPDATE - The host suffered a "Catastrophic Hardware Failure" (*specifics not shared) on 01/13 and the "latest available" backup for the website and database were restored.  At this point they have been unable to recover any later versions of the database.
     We are going to give them another 72hrs to pull off a miracle and find something later than 05/21 before we fully move forward with normal forum operations.  Maybe we'll luck out, but to be perfectly honest, it's not looking good.
     It is still recommended that new members wait to register for the time being, as any new accounts created before our final decision on a path forward is made, may not exist once this is taken care of. This is also true for new topics, posts, status updates, profile & account changes, etc.
As always, we appreciate your patience as ask that you hold on just a little longer.
-NPORA Mod Team
*Updated: 01/17/2022 6:54PM PST
Recommendation on timing belt
Azbuilt
Get the belts with the pulley orientation marks on the sides, they are quality and convenient. That would be dealership, Gates and a few others IIRC.
You can always order them from our local dealership parts pimp, Alkorahil. Great guy and prices (he can set you up with some of the other parts to change as well). Check out the Classifieds/Services section.
Yeah, I'm pimping the pimp... :D
Just an FYI since it wasn't already mentioned here. Typically, you do the water pump at the same time since its right there in front of you when you are doing the timing belt. Otherwise, if you wait for pump to fail you have to do the same tear down again and risk the timing belt by getting coolant on it.
Personally, I changed everything: crank/cam seals, thermostat, bypass hose, timing belt, tensioner, water pump, fan clutch and radiator hoses. It wasn't that expensive and I don't plan to touch anything there until the next timing belt change in 95k miles...
