UPDATE - The host suffered a "Catastrophic Hardware Failure" (*specifics not shared) on 01/13 and the "latest available" backup for the website and database were restored.  At this point they have been unable to recover any later versions of the database.
     We are going to give them another 72hrs to pull off a miracle and find something later than 05/21 before we fully move forward with normal forum operations.  Maybe we'll luck out, but to be perfectly honest, it's not looking good.
     It is still recommended that new members wait to register for the time being, as any new accounts created before our final decision on a path forward is made, may not exist once this is taken care of. This is also true for new topics, posts, status updates, profile & account changes, etc.
As always, we appreciate your patience as ask that you hold on just a little longer.
-NPORA Mod Team
*Updated: 01/17/2022 6:54PM PST
Suspension Lift Parts Question
mikestewart395
I am running 31's now, the previous owner said he did some blah blah mods, I'm not sure, but it does sit a little higher. But the wheels scrub when I am Dukes of Hazzarding it through the forest. Anyway, I seen this kit online, would I need anything else for a 3" lift or would I be ok with this kit?
https://www.4x4parts.com/nissan/pathfinder-custom-suspension-lift-p-54.html
What he said. Plus you will want to crank up the torsion bars a bit to get it back up and level. Shocks in the rear will need to be longer length, iirc there is a write-up in here for both the shocks and torsion bars. I used the full kit from 4x4parts and used the Rancho shocks, but you can get same kit with Bilstien shocks instead. I also added a steering stabilizer, but that is more a choice rather than a need.
Where do you scrub on 31's? The only place I have had problems with 31s on stock suspension was at full lock the front tire would rub the frame some.
At full turns yes but I also get airborne, hence the Dukes of Hazzard statements I make.
