AndyAndAmy Posted January 18, 2014 Share Posted January 18, 2014 Attempting to repair/replace I'd need be the water-pump on my 98 pathfinder. Question: when I take the timing chain cover off, will oil come out? Link to comment Share on other sites More sharing options...
ahardb0dy Posted January 18, 2014 Share Posted January 18, 2014 (edited) There is no timing chain the engine uses a belt, and no, no oil will come out when you remove the cover. How many miles are on the truck? Has the timing belt ever been replaced? They should be replaced around 100K miles, If your doing the water pump good time to do the belt and thermostat also. Is it a 2 or 4 wheel drive pathfinder? You may want to download the factory service manual from the garage section, it's free and very valuable to have. Edited January 18, 2014 by ahardb0dy Link to comment Share on other sites More sharing options...
AndyAndAmy Posted January 18, 2014 Author Share Posted January 18, 2014 It has around 150k miles; thanks for the info! I'd love to do all that but unfortunately money is beyond tight at the moment; the water pump is already going to cost more than we have... Link to comment Share on other sites More sharing options...
ahardb0dy Posted January 18, 2014 Share Posted January 18, 2014 what makes you think it needs a water pump? Link to comment Share on other sites More sharing options...
AndyAndAmy Posted January 18, 2014 Author Share Posted January 18, 2014 It's leaking radiator fluid where the pump is located... How do you hold the pulley to get the nut off (the camshaft pulley)? Link to comment Share on other sites More sharing options...
5523Pathfinder Posted January 18, 2014 Share Posted January 18, 2014 Here ya go... http://www.nissanpathfinders.net/forum/topic/12828-how-to-change-your-timing-belt/ Link to comment Share on other sites More sharing options...
adamzan Posted January 18, 2014 Share Posted January 18, 2014 I would seriously recommend not re using the timing belt if you can help it at all. If you re set the tension on it and it is not a fresh belt you greatly increase the chance of it breaking or stripping some teeth. Link to comment Share on other sites More sharing options...
AndyAndAmy Posted January 19, 2014 Author Share Posted January 19, 2014 Thanks guys, I realize the issue I'm faced with but I have no clue how to make a few twentys out of a couple quarters... Hopefully in the next week I can afford to replace that as well Link to comment Share on other sites More sharing options...
adamzan Posted January 19, 2014 Share Posted January 19, 2014 That would be best, you can just nurse it along for now adding coolant, even if it is just for a week or two. Is it dripping a lot or just a little? Link to comment Share on other sites More sharing options...
