pittmanjustin Posted December 8, 2013 Share Posted December 8, 2013 95 pathy 3.0 4x4 i draned the water cauesed hadnt had a thermosat in it and didnt want it to freeze up well t never got to that temp down here now when i refilled it with water with engine off its off its pouring from the left sde of the themostat houseng i cant even flill the radiator fast enough Link to comment Share on other sites More sharing options...
silverton Posted December 8, 2013 Share Posted December 8, 2013 Take it apart and reseal it. Link to comment Share on other sites More sharing options...
pittmanjustin Posted December 8, 2013 Author Share Posted December 8, 2013 i fpund the prombelm it blew a freeze plug on the top of the block Link to comment Share on other sites More sharing options...
pittmanjustin Posted December 8, 2013 Author Share Posted December 8, 2013 (edited) i fpund the prombelm it blew a freeze plug on the top of the block i was gone for a week so i guess it did get that cold Edited December 8, 2013 by pittmanjustin Link to comment Share on other sites More sharing options...
adamzan Posted December 8, 2013 Share Posted December 8, 2013 You should go buy some real coolant. Dont use straight water. Link to comment Share on other sites More sharing options...
Kingman Posted December 8, 2013 Share Posted December 8, 2013 Self inflicted for using straight water when its going to freeze... bet you won't do that again! Link to comment Share on other sites More sharing options...
pittmanjustin Posted December 9, 2013 Author Share Posted December 9, 2013 yeah i had straght water in t cause the radiator has been leaking but i got a new one right before this happened but i dont understamd u it busted the plug had drained the water and the thermosat was out and i ran it for a min after ii draained rhe radaTOR Link to comment Share on other sites More sharing options...
Kingman Posted December 9, 2013 Share Posted December 9, 2013 Freeze plugs are, well, self explanatory. They're there so when the water freezes and expands, the idea is that hopefully the pressure pops the plug instead of cracking the block. Link to comment Share on other sites More sharing options...
pittmanjustin Posted December 9, 2013 Author Share Posted December 9, 2013 i knew that but i thought i drained all the water from runnng t after drained the radiator Link to comment Share on other sites More sharing options...
Kingman Posted December 9, 2013 Share Posted December 9, 2013 (edited) Honestly man, clean up the English so we can understand better what you're trying to tell us. Help us help you. I'm not trying to be a dick but its kind of disrespectful to ask for help from others when all the effort we see from you is a garbled mess of words that are easily misunderstood. Edited December 9, 2013 by Kingman 1 Link to comment Share on other sites More sharing options...
pittmanjustin Posted December 9, 2013 Author Share Posted December 9, 2013 iim sorry my daughter has messed up most of my buttons on my laptop Link to comment Share on other sites More sharing options...
Precise1 Posted December 9, 2013 Share Posted December 9, 2013 So I get that you are asking why it popped a freeze plug when you had drained the coolant system. Well, you only drained the radiator, not the block, and running it doesn't make any difference as that only circulates water in a full, enclosed system. There are drain plugs on either side of the block, apparently low and to the back, but the diagram is poor. When filling it back up, you want to also remove the air relief plug. Go to the Garage section, and download your own free copy of the Factory Service Manual and read go to MA-11. Next time you can avoid this, but the good news is once you have new freeze plugs in, everything should be fine. B Link to comment Share on other sites More sharing options...
silverton Posted December 9, 2013 Share Posted December 9, 2013 Honestly man, clean up the English so we can understand better what you're trying to tell us. Help us help you. I'm not trying to be a dick but its kind of disrespectful to ask for help from others when all the effort we see from you is a garbled mess of words that are easily misunderstood. I'm guessing whenever he typed "t" he had meant "truck". Took me a few posts to get that. Good to hear it wasn't anything really major. I haven't touched my truck in about two or three weeks and we've had nothing but freezing weather, I'm hoping I had some sort of antifreeze mixture in it... *shrug* Link to comment Share on other sites More sharing options...
pittmanjustin Posted December 10, 2013 Author Share Posted December 10, 2013 so does anyone know if you can put a rubber expansion plug in it i tried today and when t got tight made few more lil turn and it popped out Link to comment Share on other sites More sharing options...
Kingman Posted December 10, 2013 Share Posted December 10, 2013 Its best to go get a proper one from the parts store for it and tap it in. If I was at home I'd send you one since I have quite a few laying around. Link to comment Share on other sites More sharing options...
