4 wheel wouldn't engage
#1
OFFLINE
Posted 04 August 2013 - 04:08 PM
This morning, I looked at everything, and everything is there. (Axles, driveshaft) the lever does move the switch on the t-case.
One thing I was wondering, has anyone ever had their hubs get stuck open? And not engage? I'm new so be gentle lol
sent while peering deeply into my soul.... trying to find that lost apex seal again.....
#2
OFFLINE
Posted 04 August 2013 - 04:49 PM
Yes, the hubs can get stuck, both open and closed. Have you ever taken them apart for service? It isn't hard unless you have a lot of rust, but check to make sure there are no broken items and only grease lightly on reassembly. After that I would test 4x4 engagement on a flat, dirt surface. You should be able to tell when 4x4 is engaged, but a little wheel spin should make it clear as well. That is where I would start
OFFLINE
Posted 04 August 2013 - 05:04 PM
there is another test you can do, hand rotate your front driveshaft, see if you cv arms rotate, the hubs should lock after a rotation or two, then you should not be able to spin your drive shaft. What sounds like is happening, one of your hubs is broken or seized. And obviously the one with lease resistance will spin, aka the one that's not locking. If you spin your drive shaft, when one arm rotates then stops and the other arm starts to rotate, usually that hub is the issue, if only one side keeps spinning, I'd check both.
But like he said, they aren't hard to service, just don't over grease them!
#4
OFFLINE
Posted 04 August 2013 - 07:23 PM
No I've never had mine open. (My old pathy went in 4 wheel 1 time...) I'll take a look and see what's up. Just sucked that I couldn't make it up a baby trail cause of this....
Precise1 has it right, I had the same issue in my pathy, but I just went and bought manual hubs but before I had a chance to install them, my pathy got wreaked
rip, but I still have the hubs and they are fore sale
I'm liking the idea of manual hubs (so does my dad lol) so I might just do that anyways. But I'll defiantly check them out first.
Another question. ... rear lower control arm bushings.... where can I buy some? Mine are trashed (just noticed) I'm probably gonna be upgrading all the bushings under this truck soon anyways lol
#5
OFFLINE
Posted 04 August 2013 - 07:28 PM
Check the hubs, might need servicing.
I can't recall if they are vacuum actuated or not, if they are, that's something to check.
I remember I told a friend that I wheel with, that I wanted to go manual hubs in my pathy to eliminate some of these issues and he couldn't figure out why....till he lost vacuum and couldn't get into 4 wheel on a black diamond trail.
Edited by 92Path_68CJ, 04 August 2013 - 07:28 PM.
#6
OFFLINE
Posted 04 August 2013 - 08:10 PM
I have looked into it I'm pretty sure their is no vacuum lines, I could be wrong this is a 95 pathy xe, when the axle starts rotating they spin into gear which locks up the hubs (I remember reading something here about how it works when I was in my debate)
Edited by cvdloc, 04 August 2013 - 08:10 PM.
#7
OFFLINE
Posted 04 August 2013 - 08:26 PM
Lol well that's what I like about manual, your locked, your locked, and rumor has it sometimes when you go in reverse they like to pop in and out (auto hubs that is)
Could be! I don't have mine anymore or I would look.
As far as I understand, the auto hubs must have one full rotation when changing direction before engaging again.
Out wheeling once I heard all sorts of zipping/crunching noises from the front end. Spotter thought it might have been hubs. YEMV.
#8
OFFLINE
Posted 04 August 2013 - 08:42 PM
Well I was having to rock back and forth to get off that rock.... maybe I just want giving them a real chance to lock
Pretty sure they aren't vacuum, that would be a nitemare! Lol I'll have a look at them tomorrow after work.
#9
OFFLINE
Posted 04 August 2013 - 09:12 PM
As for the rear bushings, you can get them from the dealer, some aftermarket (I found some Napa ones, I think they were as much as dealer) or you can get some poly ones from 4x4parts. They are a PIA to change if you don't have the right equipment (and still could be with the right tools), but if you go with the poly they are a 2 piece so then just getting the old one out is a pain.
#10
OFFLINE
Posted 06 August 2013 - 04:29 AM
The first time we took our 88 to Baja we got it stuck a few times with the auto hubs, as was said above about a tire rotation
or 3 ft to engage or disengage, so in soft stuff rocking back and forth your basically going to be in 2wd. We now run Warn hubs on
both our Pathys
#11
OFFLINE
Posted 06 August 2013 - 06:04 AM
both our Pathys
sounds like I'm upgrading to manual hubs lol
#12
OFFLINE
Posted 06 August 2013 - 07:58 AM
It is the easiest, most durable and reliable way if you are going to use it a lot. If you are on a budget and patient, watch 4 Wheel Parts for a sale on Mile Marker manual hubs, I got a set for $90 through them.
OFFLINE
Posted 06 August 2013 - 08:07 AM
#14
OFFLINE
Posted 06 August 2013 - 08:14 AM
#15
OFFLINE
Posted 14 August 2013 - 06:19 AM
Thanks guys been busy at work and haven't even been able to take my hubs off.... i'm staying late tomorrow for work, i'll bring my truck into the shop and tear her apart (kinda sucks being a tech... all your nice tools are at work.. lol )
#16
OFFLINE
Posted 31 August 2013 - 12:20 PM
So when I took them off one was locked solid, other was free Wheeling. So I pulled both out, greased them both, and put them back together. Hopefully it works. Lol haven't tested yet
Sent from my SGH-M919 using Tapatalk 2
#17
OFFLINE
Posted 31 August 2013 - 04:11 PM
Axles spin, but they won't catch..... so either my hubs are broken, I didn't fix them right, or voodoo isn't happening. Lol
#18
OFFLINE
Posted 31 August 2013 - 07:26 PM
Check the thicknesses of the brake plates for the hubs. The FSM has details, they should be a certain thickness to force the hub to catch.
#19
OFFLINE
Posted 01 September 2013 - 05:34 PM
can't you tell I'm pro manual
#20
OFFLINE
Posted 01 September 2013 - 05:40 PM
http://www.nissanpat...or/#entry679928
In his extra parts he has warn manual locking hubs for 75$, not a bad price at all (depending on condition) was uploaded earlier this morning... Not sure on the year of your pathy and if it will work... Just thought I would mention it
Edited by cvdloc, 01 September 2013 - 05:42 PM.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
