sroeser01 Posted June 28, 2013 Share Posted June 28, 2013 hello all i tried using the search function with no luck so ill try here. My map lights, dome light and rear cargo light all will not turn on. they all stopped working at the same time. all bulbs are brand new leds about a month old. I couldnt find any fuses related to this so i dont think its that but i really dont know what could be causing this. any thoughts or ideas would be a great help thanks in advanced! Link to comment Share on other sites More sharing options...
Towncivilian Posted June 28, 2013 Share Posted June 28, 2013 (edited) Room lamp fuse behind coin tray? Edited June 28, 2013 by Towncivilian Link to comment Share on other sites More sharing options...
Nate_NissanR50 Posted June 28, 2013 Share Posted June 28, 2013 I blew my fuse installing LED's in the dome light and It caused my map lights to stop working also, changed the fuse and it was all good afterwards. If it's 100% not the fuse, maybe the LED's draw to much power for your battery/alternator/etc. to handle and can't power up. Check out load resistors and that kind of stuff to help the power distribution. Link to comment Share on other sites More sharing options...
sroeser01 Posted June 28, 2013 Author Share Posted June 28, 2013 I forgot about that fuse box under the coin tray. Damn. Went out and checked it. Fuse blown. I think it was original from 17 years ago. Replaced and all working again perfect. Thanks guys! Link to comment Share on other sites More sharing options...
Towncivilian Posted June 28, 2013 Share Posted June 28, 2013 I blew my fuse installing LED's in the dome light and It caused my map lights to stop working also, changed the fuse and it was all good afterwards. If it's 100% not the fuse, maybe the LED's draw to much power for your battery/alternator/etc. to handle and can't power up. Check out load resistors and that kind of stuff to help the power distribution. LEDs draw next to no current. You may have blown a fuse if you installed the LED bulb backwards since they are polarized. Link to comment Share on other sites More sharing options...
theexbrit Posted June 29, 2013 Share Posted June 29, 2013 LEDs draw next to no current. You may have blown a fuse if you installed the LED bulb backwards since they are polarized. Very true, I was going to toss my led's as I thought they didn't work, then I switched them around & yea there was light! Link to comment Share on other sites More sharing options...
Alkorahil Posted July 6, 2013 Share Posted July 6, 2013 Been there done that. Usually happens after working all day and its 100F outside. "Why arent the lights coming on???" <insert small tantrum> "OH......maybe..." <reverses bulbs and gets illumination> "Ahh there we go" Very true, I was going to toss my led's as I thought they didn't work, then I switched them around & yea there was light! Link to comment Share on other sites More sharing options...
devonianwalk Posted July 7, 2013 Share Posted July 7, 2013 I was unaware of the "polarity" of LED lighting. Good to know. Link to comment Share on other sites More sharing options...
Slartibartfast Posted July 8, 2013 Share Posted July 8, 2013 I'm not sure how putting one in backward would fry anything. They're diodes, so if they're not lighting up, they're not passing much if any current. More likely you brushed a + wire against a body ground while wiring them up, with the door open (dome light on), and killed the fuse that way. I've had no problems with my LED dome light, except for the "Jesus H. tap-dancing Christ that's bright" reaction at night. Link to comment Share on other sites More sharing options...
