UPDATE - The host suffered a "Catastrophic Hardware Failure" (*specifics not shared) on 01/13 and the "latest available" backup for the website and database were restored.  At this point they have been unable to recover any later versions of the database.
     We are going to give them another 72hrs to pull off a miracle and find something later than 05/21 before we fully move forward with normal forum operations.  Maybe we'll luck out, but to be perfectly honest, it's not looking good.
     It is still recommended that new members wait to register for the time being, as any new accounts created before our final decision on a path forward is made, may not exist once this is taken care of. This is also true for new topics, posts, status updates, profile & account changes, etc.
As always, we appreciate your patience as ask that you hold on just a little longer.
-NPORA Mod Team
*Updated: 01/17/2022 6:54PM PST
Valve cover/rocker arm cover gasket replacement
Mr. Pickles
Tell me I'm crazy, but do you really have to remove the distributor to get at the last forward screw to pull the cover on the driver's side of a VG30 (94 Pathfinder)? This is getting ridiculous, I'm wrapping up a water pump and timing belt, and figured I'd better replace these leaking gaskets, but the design of this thing is a joke.
I usually use a really long screwdriver. But popping of the dizzy ain't that bad. I use a marker to color around the mount bolt, then mark where the rotor points. Pop it out then, when putting it back in, reinstall and make sure everything lines back up.
Thanks guys. I'll see if I can figure out a long enough driver but with big enough head to get that last screw. There isn't a straight shot to be had on my rig, and this is one of a few steps either left out of the FSM and Haynes manual, if not totally contradicted. I think I might have a Frankenpathy.
