The_Magicians_Eye
A Tail of Two Sisters - Build Photos and Videos
TIG, TIG, TIG... One day I will learn you.
I don't feel too bad about the look of exhaust pipes under the truck as I find I smash them so frequently. :whocares: I build my exhaust with removable sections in any of my vulnerable spots for easier replacement. Yea, skid plates, I know, I know... On the to do list.
If it was stainless pipe on a street rod I'd be all over it. :lmao:
Since it's way to cold to work in the shop and I'm on a spending freeze, I figured why not get some videos edited.
Front axle is back in. The tires and wheels are on. Need to hook up the coilovers and the front drive shaft so I can do a final suspension and steering cycle. I might have some trimming to do on the front body mount and a little on the frame but so far everything looks great.
26220110_10155300312308087_7661022765472
26170372_10155300312388087_4332061103680
26165445_10155300312358087_4490882992360
  • Like 5
Please tell me you are putting in a different rear driveshaft
Had the factory one extended. It's more than likely going to be replaced at some point though. I wasn't happy with the work they did.
Given that someone blocked me from the FB group I'm not sure why I'm even posting here anymore... I guess I'll be the better man though and continue to update my build thread.
Trying to get her wrapped up before the move. Need to finish the lower shock mounts on the rear axle and then I can get rid of the jack stands. Other than the brakes and power steering hoses, the front end is ready to roll.
Rock Crawler Mode:
29594825_1916170548458449_34510997444503
Mud Truck Mode:
29683768_1916728735069297_13931618022947
Upper Rear Shock Mounts Lots of math went into this so I didn't have to redo a bunch of work. Everything has to be just right to fit the 12" coilovers back there without cutting up the floor.
28167090_1865696263505878_32422095131636
28238998_1865696323505872_55423926327840
28377886_1865696383505866_42205915793183
28168227_1865696426839195_61801135123892
29542212_1906505242758313_87521484099894
  • Like 4
