bearindabush Posted December 18, 2012 Share Posted December 18, 2012 Where are all the Diesel topics? When I click on Diesel Engine Discussion and there is only 1 topic when the directory says 45 topics I'm confused Link to comment Share on other sites More sharing options...
Slartibartfast Posted December 18, 2012 Share Posted December 18, 2012 I think there's a setting somewhere that you can change to fix this. The forum has a 'helpful' feature of not showing older topics unless you tell it to. I don't know where to find this setting though. Link to comment Share on other sites More sharing options...
nunya Posted December 18, 2012 Share Posted December 18, 2012 its in your settings. click on your desired topic (Diesel Engine Discussion for example) The blue bar above the threads has 5 choices: Recently Updated-Start Date-Most Replies-Most Viewed-Custom odds are your still set on 'recently updated' (it will be highlighted with a darker blue oval around the text) Click Custom and it brings up a sub-menu with options of: Show topic type (default all, no need to touch)-sort by (default last post)-sort direction (default Descending)-time frame (default last 60 days) click time frame and select 'show all' for this topic as the last other topic hasn't been updated since August 29 2012 so it's the only one that will bring up the other topics. If you want it to be a 1 time effect just simply click "update filter" once selected, or you can check the "remember filters" box to keep it set to those settings (easily reversible by doing the same process back to your preferred setting as well) this can be done 'per topic' as wanted so just setting the Diesel Engine Discussion topic this way will not change How To's or R50 tech etc. Link to comment Share on other sites More sharing options...
bearindabush Posted December 18, 2012 Author Share Posted December 18, 2012 Thanks Nunya, I now see a list of Diesel topics to peruse Link to comment Share on other sites More sharing options...
