psychopathy Posted July 6, 2012 Share Posted July 6, 2012 Hi all....quick question...my blower motor is making noise and I believe it's about to go...still moves air but very noisy. How hard is it to replace (where is it? easy access?) and where is the best place to get one. I think I can do it myself... Link to comment Share on other sites More sharing options...
Towncivilian Posted July 6, 2012 Share Posted July 6, 2012 Crazy easy to access, just remove the glove box (see here if you need a guide) then it's three screws and it slides right out. Replace the cabin filter while you're down there, and wipe down the housing before installing the blower motor. RockAuto should have a few for pretty cheap; be sure to use a 5% off discount code if you order from there. A new OEM blower motor unit is $184 online before shipping. Link to comment Share on other sites More sharing options...
Alkorahil Posted July 6, 2012 Share Posted July 6, 2012 All model R50 used the same blower motor and fan assembly. PART NUMBER: 27220-7J201 DESCRIPTION: MOTOR & FAN ASSY $175.59 (NISSAN LIST: 259.34) This part is still available from nissan. If you havent replaed the air filter in ages....it could be as simple as blowing the crud all out of there and putting a new filter in. Link to comment Share on other sites More sharing options...
psychopathy Posted July 8, 2012 Author Share Posted July 8, 2012 Thank you gentlemen...I found a blower/motor assembly online that was very reasonably priced...I'll get some filters, too! Link to comment Share on other sites More sharing options...
