Towncivilian Posted March 10, 2012 Share Posted March 10, 2012 The pump works (I hear it whirring when trying to spray), the fluid reservoir is full, and the rear nozzle doesn't seem clogged. The hose end on the pump is still fine and not leaking. I haven't found a leak anywhere in the interior where the fluid line runs, though I didn't look extensively. Is there a clog somewhere, maybe the check valve in the rear door? Link to comment Share on other sites More sharing options...
devonianwalk Posted March 11, 2012 Share Posted March 11, 2012 (edited) Man, none of mine work. I need to look into this tomorrow. It's one of those "things" that I don't think about until I can't use it. *edit .. who wants to bet me that it has something to do with excessive mud? Edited March 11, 2012 by devonianwalk Link to comment Share on other sites More sharing options...
trenton163 Posted March 11, 2012 Share Posted March 11, 2012 (edited) My front ones didn't spray, I replaced the pump (it was filled with build up) and now the front work great. My rear does the same thing as yours, So I would make sure that all your pumps are clean. If they are dirty you can run some clr through them and see if that helps. I didn't work with mine so I spent 20 bucks and got a new one! Good luck. Edited March 11, 2012 by trenton163 Link to comment Share on other sites More sharing options...
Towncivilian Posted March 11, 2012 Author Share Posted March 11, 2012 Yeah, maybe you're right that the rear pump is clogged with crap. Sometimes when I fill the washer fluid, some nasty smell emerges. The tube thing attached to the cap is also full of crud. Link to comment Share on other sites More sharing options...
tmoore4512 Posted March 11, 2012 Share Posted March 11, 2012 I was tripping out.... because I cannot find my rear reservoir.... then I realized that you have an R50.... Link to comment Share on other sites More sharing options...
Towncivilian Posted March 11, 2012 Author Share Posted March 11, 2012 Once I empty my current fill of washer fluid (just topped it off today, d'oh) I'll try flushing the reservoir with a garden hose and try running some CLR through the pumps. Link to comment Share on other sites More sharing options...
OfftourRoadie96 Posted March 11, 2012 Share Posted March 11, 2012 I used compressed air through the line and mine worked again. Link to comment Share on other sites More sharing options...
Slartibartfast Posted March 11, 2012 Share Posted March 11, 2012 If the one-way valve somewhere in the tubing leaks, the fluid will drain back out, and you'll have to hold the switch for a bit to re-prime the line. I have to do that on mine sometimes, if I haven't used it in a while. Link to comment Share on other sites More sharing options...
Leo94 Posted March 11, 2012 Share Posted March 11, 2012 I was tripping out.... because I cannot find my rear reservoir.... then I realized that you have an R50.... wd21 Terranos have a reservoir for the rear nozzle Link to comment Share on other sites More sharing options...
Tungsten Posted March 12, 2012 Share Posted March 12, 2012 Remove the little spray thing and just have the line stick out then mash the wash button and have fun shooting crap out of it. Link to comment Share on other sites More sharing options...
