crash95 Posted February 28, 2012 Share Posted February 28, 2012 i need help??? on the drivers side of my 89 pathy 4x4 there is two items im not sure about....basically the little barrel that has a freespinning little plate and the big black cylinder with a few hoses going in/out it all just behind the drivers head light if anyone can tell me if these two things are 100%necessary for the running of the motor.....and also can someone give me a list of things that can be removed to add power and clean up engine bay? Link to comment Share on other sites More sharing options...
Rebel526 Posted February 28, 2012 Share Posted February 28, 2012 The one with the hoses, I believe, is the evap/charcoal canister. The other thing is MIA on my 88 Pathy, but I think it's smog related. Dunno if/what can be removed though..... Link to comment Share on other sites More sharing options...
silverton Posted February 28, 2012 Share Posted February 28, 2012 i need help??? on the drivers side of my 89 pathy 4x4 there is two items im not sure about....basically the little barrel that has a freespinning little plate and the big black cylinder with a few hoses going in/out it all just behind the drivers head light if anyone can tell me if these two things are 100%necessary for the running of the motor.....and also can someone give me a list of things that can be removed to add power and clean up engine bay? Pictures would help of the items in question. You need a more informative thread title, I can see you're new to forums in general, so that's okay. Just in the future, use a better title. The black cylinder with hoses come out of it is generally called a charcoal canister, it's a smog related item that helps with fuel vapors from the gas tank. The other item also sounds smog related, and someone with a TBI truck should be able to help you out with identifying it. Link to comment Share on other sites More sharing options...
