Stock Spare Tire Carrier Mod.
So I need to complete a few things before I can finish my rear bumper. Here's the first step in completing those tasks.
I relocated my spare tire location on the stock carrier. I moved it up about 6 inches and over the the passenger side to help eliminate the leverage it's putting on the carrier.
The welds look like complete @!*% because I'm using a 90 amp harbor freight welder. So no close ups lol. I basically cut out the plate that the tire mount bolts to. Moved it over one section and up about 6 inches and welded it back on.
Next steps to come:
1. Remount my hi-lift.
2. Relocated my license plate to the center of the spare.
3. Build a removable fuel can carrier that will hold two cans on the driver side of the spare.
4. Finish my rear bumper.
5. Post pics on NPORA lol.
Blind spot I would assume, like the big mirrors you see mounted on the back corner of some delevery vans. :shrug:
TME, that tire being moved up a little affect visibility at all? (meant to ask originally)
It's kind of a give and take. It blocks the passenger side view but it opens up the center quite a bit more. It's not bad. Nothing that should bother anyone. Put an adult in the passenger rear seat and they will block the view just as much. I like that the center view has a better viewing angle though. In my opinion it's way worth the trade off. Plus if you look at my 2011 truck of the month shot you well see I was dragging the spare on the ground. So yeah it had to be raised to prevent that. There is one major perk though. It moves all that weight closer to the hinges and relieves quite a bit of the pressure put on them.
