Pillar Gauge Pod
Alkorahil
I had all these from one of my two 300zx z31 turbos that i had kept around from when I upgraded to digital AEM ones ha so it worked out well but I think you have the same ones right? Autometer?
Yes, I do and yes, Autometer. They look almost exactly like the stock gauges and are reasonablely priced, so it works for me! :aok:
how did you get yours to work? im having trouble wit my temp gauge. All the other gauges work fine my temp one doesnt move past 110 degrees. I have 1 wire to ground, 1 to switched 12v and a 18gauge wire to the sensor in the upper rad hose in a temp sensor adaptor. I figured mayby sensor was bad but i helpd my buddy wire a new but same gauge into his s13 and he has the same problem....any ideas?
I had the same problem, until I ran a ground directly to the sender
Edited by vagabond
