onefast87 Posted July 30, 2011 Share Posted July 30, 2011 The install was straight forward.All it took was the help of a good friend. I like the way it came out. I used a Hayden cooler.The cost was about 90$ total, took about 2-3 hours.I would still like to get a Temp gauge. The next project will be a remote turbo. http://www.oreillyauto.com/site/c/detail/HAD1/404.oap?ck=Search_N0940_-1_-1&pt=N0940&ppt=C0377 Link to comment Share on other sites More sharing options...
silverton Posted July 30, 2011 Share Posted July 30, 2011 I used a Flex-a-Lite 4118 (18,000LB) on my truck, the dimensions are almost identical. I put mine in the same place, but ran the lines underneath the radiator. shortest route to the transmission lines. Under heavy load, it won't go above 150*. I'll have to haul something sometime and get a temp reading.... Link to comment Share on other sites More sharing options...
trenton163 Posted August 5, 2011 Share Posted August 5, 2011 Nice, I installed one in-front of my AC condenser, you can feel a major difference in heat just from driving. Best 100 bucks I ever spent. Link to comment Share on other sites More sharing options...
Tungsten Posted August 5, 2011 Share Posted August 5, 2011 The trans temp only goes way up if you shift at the redline (or in POWER mode) if you really want to test how well it performs. Link to comment Share on other sites More sharing options...
